Question about Comfort-Aire 9,000 BTU Mini Split Air Conditioner
I have a confort aire mini split inverter model A-VMH18SB that constantly trips the circuit breader,
Compressor guaranteed till 2016
Hi, when i turned on my Senville mini split the fan will go on for 2 - 3 minutes and then the air conditioner will display P4. On the error code description, it say inverter compressor drive error.
contact the manufacturer to see if they can help you with this type of failure. the compressor and its controller are the two most expensive parts of the unit to repair.
Jul 29, 2016 | Inverter Heating & Cooling
Compressor runs after 5minutes stop.kollin 1hp split wall inverter
Check thermostat setting outdoor unit fan motor its possible outdoor unit fan motor not running then its possible to compressor getting heat up and trip off .
Jul 24, 2016 | Inverter Heating & Cooling
I have a 2008 samsung mini split mho50fxca2a with a I trip pfc overcurrent error what is this and where to start? also shows e4 67 which is compressor rotation error?
Your 2 errors are most likely related to the compressor itself and the power supply feeding it. If the system is an inverter system, there is usually an "inverter board" or power control board that sends high voltage (usually in DC rectified voltage) to the compressor. If the board is not functioning correctly or if there is an issue with the compressor, it may cause a reverse rotation error along with the power error. Additionally, the compressor itself may have failed and may have shorted or welded windings. This condition can be especially dangerous due to the potential of electricity arcing and the possibility of refrigerant loss. If you are not a technician trained to work on the equipment, I would NOT advise attempting a repair. Some of the power supplies in those units can discharge over 300v DC and there are quite a few components that can cause serious injury. I would call a technician to diagnose the issue.
Jul 18, 2016 | Samsung MH050FXCA2A 24000 BTU 2 Ton Dual...
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
COLMAN TSR
3000 Watts is a little short on the power necessary for the compressor to restart. When it compressor starts it may draw 27 amps or more for a split second. 3000 / 120 = 25 amps. when the fan slows down it is telling you the voltage has dropped and it doesn't have enough power. After the pressure has balanced out in the A/C system the compressor can start against no pressure difference.
Jun 16, 2008 | Coleman Mach 15 Air Conditioner
Comfort-Aire 9,000 BTU Mini Split  Air Conditioner Logo
Top Comfort-Aire Heating & Cooling Experts
Ottoniel
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
