Question about Siemens Washing Machines
HELLO I TRY TO FIND THE MANUAL OF THE OLD MODEL WK61420EU/13 IN ENGLICH
My Nikon f-601 does not show the Fokus poin and the light skale anymore when looking throuhg. It only shows it on the top. . (don't know the englich words, sorry). So I can not choose the right ti
Try taking out the card and batteries then start it up fresh sometimes a restart will do the job simply because the camera has lost its memory .
Sep 23, 2012 | Nikon F601 35mm SLR Camera
Hi, I am thinking about buying a logik lbfanx10 oven but I understand it has to be hard wired. My old oven is simply fitted with a 13amp plug and it just plugs into a socket. As I do not know the power...
The following website installation and user manual indicates a current value of 13-15 Amperes. You may have upgrade the wiring and the plug.
https://www.manualslib.com/manual/935752/Logik-Lbfanw10.html?page=11#manual Specification Model LBFANX10
Rated Voltage 230 - 240 V
Rated Frequency 50 Hz
Power 3200 - 3500 W
Current 13 - 15 A
Top Element 1200 W
Bottom Element 1100 W
Oct 10, 2017 | Ovens
I received a garmin nuvi and two instruction booklets but neither are in englich
  • Go to www.garmin.com.
  • At the top of the screen hold the mouse over SUPPORT and when the menu drops down click on MANUALS
  • Click the drop-down arrow and select ON THE ROAD
  • when the next drop-down arrow appears click AUTOMOTIVE
  • When the next drop-down arrow appears select the model of your satnav.
It will produce a list of the documents available including the user manual. If you're not sure which one is the manual select the biggest file size and click on it. It will open the manual and you can save it to your computer or print it.
Jul 14, 2011 | Garmin GPS
Hello,i have samsung 13" tv
The original remote has an infrared sensor that you point to the tv "looks like a led except it see through" it has become defective and must be changed, some service shops may carry some, also try Radio Shack.
Feb 06, 2011 | Samsung TXJ1366 13" TV
My nikon D 90 whit an old lince 28-105 will not auto focks an offen not take pictuers. WHY not???? must i go too the shop wher i bought it or am i douing somthing wrong??? i am from Denmark and my englich...
Hi Annette,
The Nikon D90 will take pictures with many older lenses, however there are some problems with using these lenses. Most of the time, they will not auto focus and many depending on type lens may not work in any mode other than "M" (manual). No P, A, S, AUTO or any of the "Scene" modes.
Set to "M" (manual)
You will have to set the exposure values (aperture & exposure time) and focus manually. Ken Rockwell has compiled a list of lenses that may help you learn more about using older lenses with your D90.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Nikon D90 Digital Camera with 18-105mm...
Hello, i was given a durabrand tv with no remote. I would like to know which remote i can use to programme it. The model is DCT1303R and the serial number is M2533425B
http://remotes.com/store/durabrand/dct1303r.html
if you want the OEM replacement - The original is $40 plus S&H.
You could try a Phillips Universal remote for ~$15, their manual lists Durabrand, but the model numbers skip the 1303, so it may not have full function.
Try Googling the Brand, Model, and remote to see if you can do better.
Nov 16, 2009 | Durabrand BH1304D 13" TV
Only stays on Channel 2 can't watch DVD's
hello, get a remote from key electronics.
info@key-electronics.co.uk
they will sell a remote to you if they have them in stock , ask about a manual too.
ive spents weeks trying to get help about our tv and wow at last we have some...
christine.....
May 01, 2008 | Disney DTD1363-CAR 13" TV/DVD
CANON LBP 5200 error code100
Canon Laser all in one printer copy fax laser
when setting the printing preverencens it comes in the Spanich
lanquis how can i change it all the other ones are in the Englich installed from the driver It only do this in Vista not in XP pro
My old laptop in XP Pro works fine
my new laptop Toshiba and vista that is what happen
Jan 07, 2008 | Canon LASER SHOT LBP-5200 Printer
Washing Machines Logo
165 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
