Question about Exercise & Fitness
Johnson's treadmill error codes error 3
Error 3 when start pls give me a good sulu shin
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
SOURCE: Error code "SI 2" for ironman triad treadmill
You need to replace the motor control board located in on the base. If your both motors work along with your display added that you've done the reclibration then you must replace this board. I did and the unit works so far. 200 dollars is what you wil be spending.
Posted on Apr 16, 2010
  • 33 Answers
SOURCE: E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
What are shin splints treatments?
In most cases, you can treat shin splints with simple self-care steps:
Rest. Avoid activities that cause pain, swelling or discomfort — but don't give up all physical activity. While you're healing, try low-impact exercises, such as swimming, bicycling or water running.
Ice the affected area. Apply ice packs to the affected shin for 15 to 20 minutes at a time, four to eight times a day for several days. To protect your skin, wrap the ice packs in a thin towel.
Take an over-the-counter pain reliever. Try ibuprofen (Advil, Motrin IB, others), naproxen sodium (Aleve) or acetaminophen (Tylenol, others) to reduce pain.
Resume your usual activities gradually. If your shin isn't completely healed, returning to your usual activities may cause continued pain.
Sep 15, 2015 | Health & Beauty
What are the effective ways you can treat shin splints from home when they do occur?
Here are 4 effective ways you can treat shin splints from home when they do occur.
1. Get Some Tape
Using a bandage or special sleeve that fits comfortably over the lower leg region, helps to reduce pain and swelling. Furthermore, it bolsters your tissue area, improving flexibility and good conditioning around the adjoining muscles.
Ensure that you work gingerly, never hurriedly (that's if the pain permits you). You can use a walking stick if the pain seems unbearable. This stimulates healthy blood to the damaged tissue area and also removes surplus fluid caused by the swelling.
2. Use an insole
Shin splints happen because of the continuous jarring of your joints and shins during intensive work outs or heavy impact activities. When you have shin splints, start wearing a padded insole with your shoes. This has been known to offer great relief. A padded sole helps to cushion the blow of your foot every time it thumps on the ground, especially on hard or uneven surfaces. You can get insoles at specialty stores or at the sport section of any other store.
3. Ice Treatments
Ice therapy reduces swellings and inflammation fast and is a reliable method that will provide relief from shin pain. Break ice in a towel and apply on the affected area for 10-15 minutes every day. Do this dutifully at least 3 times daily. If you do not want it to affect your other activities or chores, use an ice pack held in place with an elastic bandage. Never apply directly to your shin; it does more harm than good! Are you having trouble, finding the specific tools for the job? You can turn to the kitchen for a solution to your throbbing splint by opting for a bag of frozen legumes or vegetables. They work as well.
4. Pop the Painkillers and Rest Up
Taking Aspirin, Acetaminophen and ibuprofen with water will help relieve shin pain by reducing swellings and inflamed muscles. These painkillers, along with rest, gradually help to return your body to full activity. Pregnant women or nursing moms need to check in with their doctors first before using these medications as they are known to have possible side effects.
Sep 15, 2015 | The Health & Beauty
Will stretches helps to cure shin splints pain?
Common sense as well as research proves that muscles are more elastic after they have been warmed up so shin splint stretching should take place as part of a good warm-up as well as at the end of the workout.
You may also want to set aside some time for a specific splint stretch session 2-3 times a week if you feel the need.
What kinds of stretching help to cure shin splints?
Do some stretching and muscle conditioning before any activity. If you subject your muscles to immediate exertion and stress without warm-ups and stretching, you run the risk of worsening your shin splint problem. Proper stretching will prepare your muscles for any long-term activity, keeping it loose and ready. Proper stretching of the injured muscle can also help in the healing process.
HI, i have acer ms2264 which is locked with hard disk password. but client couldnt remember their password. when i give 3 wrong password it gives me hint and i generat master password with bios_pw.org. But...
this may not work for the problem you have but you can try it....you will have to open the laptop up to do this,,,,look for the cmos battery its the small round silver battery that is on the mother board,,,take this out for a couple of secs then put it back,make sure you turn the laptop of first.
nothing lost if it dont work,,good luck.
Jun 11, 2014 | Acer Aspire Computers & Internet
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Icon extractor fan covers do not close completely
I have no idea of what you are talking about, but it sounds COOL!
("Alright Mr.Sulu, retract the Extractor Fan covers, on my mark......."
I need more POWER, Scotty!"
"I'm giving all she's got Captain!")
Post back in a Comment, David
Regards,
joecoolvette
Apr 13, 2013 | Computers & Internet
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Onboard lan not working even after update of driver gives windows error
Hi Good day!! What message of windows error? Check your network adapter in the device manager, if it is install if not pls try the following.
1. On the desktop right click "My computer and then properties"
2. go to Hardware tab and then click device manager check the network adapter.
3. Disable it and then re enable it. hope your on board lan will work now if still not re-install your lan driver through your motherboard cd..
pls reply o assist you more..
REGARDS:
JR
Oct 07, 2010 | Biostar TA785G3HD AM3 AMD 785G HDMI Micro...
My acer 5620 laptop boots up with a sharp long sound that goes on for at least more than 3 -4 minutes and stops when the xp sign apprears. Pls tell me how to fix. Solz
Try taking the ram out and giving it a good clean. Then reinsert it. While your at it might as well give your entire laptop a good cleaning, get yourself a can of air.
Hope this helps, give me thumbs up please!
Aug 23, 2010 | Acer Extensa 5620-4020 Notebook
Exercise & Fitness Logo
89 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
