Question about Irons
Beeping won't start - Irons
Why does my iron contantly beep and no steam?
Hi Mary,
Check to see that your iron is set at a temperatures suitable for steam generation. Beeps are a usual signal to notify you that your iron is plugged and switched on but the temperature setting is low and cannot generate steam.
Oct 05, 2014 | Irons
My sunbeam iron started beeping like an alarm, why?
www.laundry.manualsonline.com has free manual
May 22, 2014 | Sunbeam 4214 Iron
MANUAL FOR PS 350 HOME TOUCH GARMENT STEAMER
First-time ever used. Water filter installed. WON'T STOP BEEPING AND START STEAMING.
Mar 03, 2012 | Irons
My iron worked perfectly and suddenly started beeping and all of the lights went out and it no longer heats up. It is only 2 years old with not much use.
Try wiggling cable at plug and then at iron side if light flashes you have a broken wire.
Tick box if helped
Sep 02, 2009 | Irons
Beeping and error message
Your Iron has a faulty circuit board and need to be replaced
Jul 23, 2009 | Black & Decker D2030 Iron
Continuous beeping sound
did you get an answer? mine is doing the same. I've filled it, checked the float, held the trigger for a good while, won't stop beeping or start working again.
steamed,
art
Jan 11, 2009 | Irons
Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 11, 2008 | Black & Decker D2020 Iron
My iron bahaves very bad
Izula,
We have had two D2020 Black&Decker Irons that did exactly the same thing. I love the iron...but they have both lasted about 2 months before burning!
Dec 02, 2007 | Black & Decker D2020 Iron
Irons Logo
22 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
