Question about Water Heaters
F70vaillant boiler fault codes - Water Heaters
Hello. I have a vallient ecomax 828 which is displaying the F40 fault code after a power cut earlier today. The boiler sounds like its running, but nothing is happening.
F40 is a fan fault. this fault normally comes up when the fan doesn't turn, you need an engineer to fix this, i could tell you how to fix it but its best left to a gas engineer
Feb 05, 2018 | Water Heaters
How do i reset the thermal cut off switch on a vaillent boiler?
Hi, what model Valliant and are there any fault codes showing?
Feb 21, 2015 | Water Water Heaters
Ideal icons boiler fault code h1
ideal icos
H1 fault
FLOW THERMISTOR
part number 170917
check wiring to flow thermistor NOT loose first
Sep 16, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Code f28 what isit?
According to the user's guide, the fault code means that the boiler failed to start after 5 attempts. Here is the manual where I got the information. I would confirm the codes with your particular model. I am presuming that the codes would be standard for all their models. Source(s): http://www.vaillant.co.uk/stepone2/data/…
Mar 10, 2010 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Oct 29, 2008 | Water Heaters
Water Heaters Logo
14 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
