Question about KitchenAid Pro Line Coffeemaker Coffee Maker
Coffee stops brewing in middle of cycle about half pot. if i wait 5 min and turn it back on it will finish brewing
  • 145 Answers
SOURCE: kitchenaid coffee pot won't brew coffee reads err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
SOURCE: My Survival Guide To The Dreaded Err2 Disaster
Well, I am not happy to read that we need a new coffee pot since this WAS the new coffee pot we bought to replace the last one that up and stopped making coffee. Yes, this coffee pot is less than two months old! Err2 means we need a new coffee pot? It won't be a KitchenAid!!!!!!!!!!!!!!! We want our money back!!!!!!
Posted on Sep 01, 2009
SOURCE: Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
Posted on Dec 21, 2009
SOURCE: Error 2-Unit will not heat or brew. Stopped in
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
Posted on Dec 31, 2009
  • 906 Answers
SOURCE: my kitchenaide coffee pot says error 2 before it
good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 02, 2010
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Coffee pot turns stops brewing in the middle of the cycle
If this is not an electrical problem, try the following:
Try running a cup of WHITE vinegar (of course without the coffee), this will clear out anything on the path.
Once you do this, run 5 cups of plain water (again without coffee) twice to clear out any vinegar flavor from the path.
Feb 01, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a Mr. Coffee model JHX33 coffee maker, and have lost the owners manual I need cleaning instructions. Can you possibly help me?\r\n Thanks Eddie Thatcher
mcdevito75 here, I too have a Mr. Coffee, coffee maker 4 cup. The instuctions shold be just about the same for both our Mr. Coffee mavhines, ------ With a new or clean filter in the machine fill the pot 3/4 way full of White Vinegaar the pour that into the resovior, place thepot back in place on the machine and start the machine up, let the vinegar cycle thru, when done the vinegar is now in the pot, empty the pot back into the resovoir, and cycle again, this time 1/2 way thru the cycle or pot half full stop the cycle for 30 mins. this will keep the vinegar in the machine and claen all the little ports. After 30 mins, complete the cycle. repaet this 2 more times. Then repaet once the machine is cool but this time use plain water, repaeat plain water cycle 3--4 times to clean out all the vinegar, Mr. Coofee needs claening when you notice coffee brewing has slowed down or maCHINE STEAMS TOO MUCH DURING BREWING CYCLE.
Jun 19, 2010 | Juicers
When i make coffee sometimes the water that comes out is cold or luke warm
The brewer has not had enough time to reach its operating temp (usually 7 mins after a brew cycle). If that is not hte case then the machine needs to be descaled.
Feb 18, 2010 | Bunn VPR Coffee Maker
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Coffee starts to brew and then stops
You could turn it off, unplug it ( is it plugged into a GFI outlet?) empty it of water and clean every part that you can get off it thoroughly. then dry it carefully and then plugging it back in and just try running water through it with a filter in place. This is just a simple reset. (Even coffee pots are computerized now!)If this does not change anything,
I would clean this pot, put it back in the box and take it back to the store where I purchased it, along with the receipt or credit card receipt. I would not take "no" for an answer. You should not be having these problems after ten uses. Let me know how it works out.
Thank You Your rating is always appreciated.
Aug 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
KitchenAid Pro Line Coffeemaker Coffee Maker Logo
32 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
