Question about Sharp AL-1642CS Copier
How do i connect my sharp AL 1642cs to laptop with usb
  • 29 Answers
SOURCE: My Sharp AL-1642CS is a
try to check the safety lock under the scanner unit.if the lock is in the lock position unlock it.
Posted on Mar 25, 2008
SOURCE: Sharp copier AL-1642CS
Here is what worked for me.
You need to alternate pressing the clear button then one of the auto buttons until the display lights turn off.
First press the clear button (red letter “C” on the unit) then the auto button. (below the word auto there are 3 buttons. Press the one on the far left that has no other markings on it. This will only take 2 or 3 times back and forth.
When the display is blank enter the number 14 (like you were making 14 copies of something) then press the Green (start?) button. Let the copier warm up about 30 seconds and try making a copy.
It worked for me. Still having trouble call Sharp USA 630-378-3590 or Canada 905-568-7140. They were quick and helpful
Posted on May 27, 2008
Bubbabear64
  • 2794 Answers
SOURCE: sharp copier al-1642cs
This error is caused when the scanner glass is in the locked position. Make sure it is unlocked underneath the scanner on the left side.
If you look into the scanner is the ribbon cable tangled up or frayed?
Posted on Jun 09, 2008
mickspaceNET
  • 115 Answers
SOURCE: sharp 1642CS shared printer
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
Posted on Nov 05, 2008
rylee_smith
  • 8619 Answers
SOURCE: I have a L1 display on my Sharp AL 1642CS
Hi
Thanks for using FixYa. The error code L 1 on Sharp AL 1642CS Copier means that the switch on the upper side (optical system) of paper exit tray has been locked and you need to just put it in the unlock position. The error code will be cleared.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 20, 2009
Can the Sharp al1642cs work with just usb connection?
I've been using my AL1642CS connected by USB to my Windows XP Pro desktop for about a year now - very reliably - both for printing and for scanning. I love the duplex print feature, so much easier on the trees!
I've also printed to it through the USB port on my network router - but then I can't use it for scanning since Microsoft never enabled network scanning - only network printing!
Dec 06, 2010 | Sharp AL-1642CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
Error code h4 on sharp al-1642cs
I have a solution for this posted in the tips section. Just search for Sharp AL H4
Jan 16, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
Drivers Sharp al 1642cs para vista 64bits
Ir a la ficha www.sharpusa.com de atención al cliente a continuación, descarga de productos. Categoría de producto elegir impresoras y multifuncionales. para el modelo seleccionado modelo no figuran a continuación, el tipo de modelo en AL1642CS. Para el tipo de descarga a continuación, elegir controlador presión de búsqueda en la parte inferior.
translated by goole
May 28, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS
Hello sir; I believe that's drum cartridge problem try to change that see what going to happen.
Jan 22, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Scan to pdf
TRy reloading printer driver if this doesnt work try to scan using adobe photoshop
Jan 12, 2008 | Sharp AL-1642CS Copier
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
16 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
