Question about Pantech Link P7040
Pantech P5000 won't turn on
Battery ok phone won't turn on
How do i set the time on a pantech p5000?
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauderâ„¢ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Nov 01, 2015 | Pantech Cell Phones
Pantech user manual
http://bit.ly/K74fpu
It's the third link, Change the ringtone
Dec 26, 2013 | Computers & Internet
Pantech link II unlock
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 25, 2012 | Pantech Link Ii - P5000 - Cellular Phone -...
Unlock pantech p8000
How to enter the Unlocking Code for a Pantech Model phone Option 1 - Pantech Models
1. Turn on your phone with an original SIM Card in it
2. Type the following: * # 8 6 5 6 2 5 #
3. A 'SIM Unlock' Menu will appear, press Ok
4. Enter Unlock Code + * (8 digit code)
5. Re-enter Unlock Code + * (8 digit code)
6. The phone will display 'Unlock Process Complete'
7. Press Ok
7. The phone is now unlocked.
Option 2 - Pantech Models
1. Insert a not accepted SIM Card and turn the phone on
2. When prompted, enter the unlocking code provided
(Note: Use the onscreen keyboard and make sure that wireless mode is off)
3. Your phone will now be unlocked.
Option 3 - Pantech Models
1. Insert an non-accepted SIM Card and turn ON your phone
2. A hidden 'Sim Unlock' Menu will appear
3. Enter the Unlock Code provided
4. The phone will display the message 'Unlock Process Complete'
5. The phone will now be unlocked.
AT&T Pantech Crossover P8000 Unlocking Instructions
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone.
Reasons to remote unlock your AT&T Pantech Crossover P8000:
* If you are travelling, buy a local SIM card and save on roaming fees
* The resell value of AT&T Pantech Crossover P8000 will increase significantly as it is available to more carriers.
* Easily switch between SIM card, using the same phone.
* Unlock your phone from the comfort of your own home
* You never send your phone to anybody.
* There is absolutely no risk of damaging your AT&T Pantech Crossover P8000 by unlocking it.
* Very easy, no technical experience necessary.
* The phone is permanently unlocked, even after updates
* Warranty will not be voided by this Code
* 100% Guaranteed, if we cannot get you your unlock code we will refund you no questions asked.
Jun 29, 2012 | Pantech Crossover (P8000)
My pantech laser won't charge what's wrong
if you move the cable around just right will it charge?
if not u could have some kind of damage. did you drop it
i would just try buying a new battery on ebay they are usually pretty cheap online.
if you charge your phone alot and overnight. thats really bad for the battery
Sep 26, 2011 | AT&T Cell Phones
My phone reads that i have an invalid sim card when i turn it on.
If the Phone shows Invalid Sim message means it locked to some Network,find out the Country,it's network it locked now ..then get the Unlock code from here
Onlinegsmunlock and Unlock it....Then You can use any GSM Sim card....
Pantech Pursuit Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Pantech Pursuit mobile phones. If you enter over a certain amount of wrong unlock codes on your Pantech Pursuit mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Pantech Pursuit with its ORIGINAL SIM card.
2. Type *#865625#.
3. A SIM Unlock Menu will appear, press OK.
4. Enter Unlock Code.
5. Re-enter Unlock Code.
6. Pantech Pursuit will display Unlock Process Complete. Press OK.
7. Your Pantech Pursuit is now unlocked.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the Pantech Pursuit.
Jul 12, 2011 | Pantech Pursuit P9020
My pantech laser phone won't charge no longer, what does that mean?
Try plugging it into the computer with the USB. It's on the charger cord (pulls apart) . The phone will charge from the computer, if it does then it is the wall part that is fried. If not then the Battery. If you have a MINI USB from another product that fits try that one too. I have one from that fits. It's from the Plantrnics, same size. So check any you have laying around.
Jun 21, 2011 | Pantech Standard Battery for Pantech Laser...
I ordered a new cell phone charger for my Pantech Slate but it want come on now?
Hi,you can still check if the battery cell is too weak to power up the phone or is dead. You can use another battery to test if the battery is still ok.
Take care.
Oct 01, 2010 | Pantech Slate Cell Phone
Pantech Link P7040 Logo
52 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
