Question about HP LaserJet 1022 Printer
1022 all fault lights flashing in sequence continually
Kenmore elite dishwasher smart wash flashes
This sounds like a door switch that is faulty on your main door so the system gets a signal saying its not closed properly and there for signals fault
Dec 20, 2013 | Dishwashers
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
Triangle red light is flashing HP laser jet 1022
check paper jams, open back over check paper path sensor flag and cartridge sensor flag for dislocation or spring mis place..
Sep 13, 2011 | HP LaserJet 1022 Printer
My display keeps shutting off five minutes after starting to watch TV- the sound continues, but the screen is black and the red warning light flashes
Please check the sequence in which your warning light flashes.
I will tell you what might be the problem according to the fashing of warning light,
If,
Flashing repeatedly --- Improper voltage supply
Flashing once --- Malfunctioning of fan
Flashing twice ---excessive temperature
Flashing 3 time or more--other problem
When flashing occurs please remove the power cord from receptacle and inform your dealer about the flashing sequence.
Thanx
Jul 02, 2010 | Fujitsu Plasmavision 42" TV
HOLD LIGHT FLASHES & TRANSMISSION DOES NOT ENGAGE
The bad news: your vehicle's computer has detected an internal fault in your transmission.
The good news: your computer may be flashing a fault code 'sequence' through the 'hold' light. Observe the code sequence to determine how many long flashes and short flashes occur - long flashes represent the 1st number, short flashes represend the 2nd number (e.g. 3 x long flashes - pause - 2 x short flashes, denotes code # 32).
If you are able to report back with a code of any sort, I may be able to advise the likely fault.
Cheers,
"If this has helped you in any way, please rate this solution"
Jul 02, 2010 | 1993 Mazda Protege
Indesit DI 620 dishwasher lights 2 and 4 flashing
Lights 2 and 4 flashing - can't start machine. This fault not covered in manual.
Apr 21, 2009 | Maytag MDB5100A Dishwasher
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
I have one light flashing on the console, ive looked up the code, it is 1022. Any solutions? Thanks for any help in adavance. Paul
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
did you try an new cable? there has been alot of talk about the video chip getting to hot. see Xbox-Scene.com go in the forum
Feb 12, 2008 | Microsoft Xbox 360 Console
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
HP LaserJet 1022 Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
