Question about Coffee Makers & Espresso Machines
Model no: DC133 Delonghi coffee machine
All sudden does not work no signal of power or heat to run water in order to make coffee
Noggin
  • 944 Answers
SOURCE: DeLonghi Alicia EMK6 - H20 error
Here is the link to the instruction manual if you need it; http://www.delonghi.co.uk/pdf_files/EMK6.pdf There is no information regarding this error message available online, but I think you are right and it relates to water - probably the sensor of the water level is stuck/blocked/scaled up. you can try descaling using white vinegar 50/50 solution with water, leave it overnight. Give the whole unit a good shake, in case the level sensor is a mechanical float device and it is stuck. See if any change. You can call Delonghi/Comet from this link; http://www.delonghi.co.uk/service_info.php hopefully they will tell you for certain what the error message means - if they do and it is different from what is discussed above, then please ask again if you want to try and solve the problem yourself. Hope this helps :)
Posted on Jul 31, 2007
SOURCE: Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
  • 7 Answers
SOURCE: My deLonghi Magnifica EAM3200 coffee maker is
I have the same problem, it leaks all over the place and makes a mess inside. Initially it just seemed to leak steam but it got worse and worse until now it leaks water badly. I took it apart and it appears to be a small orange silicone seal that's bad. The seal is located on the plunger that compacts the grinds and then forces water through to make the coffee. I took mine completely apart but I think by using a stubby Phillips you could remove the small black cap and replace the O ring easily. The O ring on mine that is torn is about .35" OD and about .15" ID.
To check if this is the problem on yours; turn off the machine and remove the main filter unit by pressing the two red "press to remove clips" and pulling the unit out. It will not come out with the machine powered on. Now look up into the top right hand corner and you''ll see the plunger and heater unit angled towards the center of the machine. There are two small stainless countersunk Phillips screws. Remove these and you should be able to see the small orange silicone O ring in question. Might be a good idea to replace the large one as well as it now pops right off and you can certainly clean around it now, something I was never able to do before. My small orange silicone O ring was torn into two pieces and I'll replace it tomorrow and see if it helps.
Posted on Jun 14, 2010
mcdevito75
  • 1970 Answers
SOURCE: i need a manual for my delonghi cafe parma machine
mcdevito75 here, You may be able to get the manual online at Delonghi Caffe espresso machine.
Posted on Jun 20, 2010
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Not brewing
it sounds like the pump inside is bad, from either a clog or fuse perhaps.the pump sends the water thru so thats the likley problem.
Sep 13, 2007 | DeLonghi DCM485 Coffee Maker
Prima donna coffee machine hot water spout not working
does it get past the waiting part if not try resetting coffee maker by disconnecting from power point for 24hr the try unit again.
Sep 06, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi rialto eam4500: Lost Hot Water Spout. Where to get one?
I had the same problem!! I was able to find one on Amazon:
http://www.amazon.com/DeLonghi-5532124900-HOT-WATER-SPOUT/dp/B002EKFX06
It works on 4500 as well as a couple of other models :)
Jul 25, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Water not pumping
Typically this is caused by the heating/water unit inside the machine drying out. Not being totally familiar with your machine let me offer this suggestion: if you have a "hot water" function that allows you to run hot water out of the machine use it to allow water to get back into the heating unit. Once water flows through without interruption you should be able to brew coffee again. I know this is the case with Jura machines and the problem you described is identical to what happens with those machines when the internal heated water tank runs dry.
Mar 30, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
How to flush Delonghi Macnifica Coffee Machine - not latest model
I bought a cafe parma (delonghi) on e-bay and was disappointed that it was so mineral-encrusted when it came. I was afraid to even plug it up -- much less run any water through it.
I mixed up hot water and vinegar and poured it inside. Lots of solid flakes emptied out the top a couple of times. Then I mixed up a final solution of water and vinegar and ran it through the machine.
I had been running a motorized Hamilton Beach model for about two months. And it had quit siphoning water. I couldn't find the Black and Decker or Mr. Coffee models similar to the one I had been running for years. They looked the same as the Cafe Parma model.
Now my Cafe Parma is making great expresso!!! I'm getting ready to take the Hamilton Beach apart. It will probably end up in the trash. It was 40 bucks on clearance at Wal Mart.
Mar 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
Delonghi Coffee Maker
You need to take the unit to an authorized repair shop and have the heating element replaced
Sep 01, 2007 | DeLonghi DCM485 Coffee Maker
Cafe late maker
I have exactly the same with my machine - only solution i found is to microwave the milk halfway first - bit of a pain but especially milk from the fridge takes a fair bit to heat up. Increasing the amount of water you put in can increase the amount of steam, but also of course messes with the coffee too. start trying to steam from the moment the coffee starts running through. If you need the instruction manual you should be able to get it on this link with the model number, if not post back with that and i should be able to find it for you; http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines Hope this helps :)
Jun 26, 2007 | DeLonghi Caffe Parma Espresso Machine
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
