Question about Estate Washing Machines
RINSE WATER KEEPS RUNNING DURING RINCE CYCLE - Estate Washing Machines
  • Estate Master
  • 5,323 Answers
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
RINSE WATER KEEPS RUNNING DURING RINCE CYCLE - 23507579-5l44rnzs0d0ajyywclqoqvey-2-0.jpg
RINSE WATER KEEPS RUNNING DURING RINCE CYCLE - 23507579-5l44rnzs0d0ajyywclqoqvey-2-5.jpgages/23507579-5l44rnzs0d0ajyywclqoqvey-2-5.jpg" alt="23507579-5l44rnzs0d0ajyywcRINSE WATER KEEPS RUNNING DURING RINCE CYCLE - 23507579-5l44rnzs0d0ajyywclqoqvey-2-9.jpg
Posted on Apr 25, 2016
  • 4 Answers
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    BNewberry
    • 93 Answers
    SOURCE: water barely trickles out for rinse cycle
    It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
    If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
    If you have anymore questions about this please ask. I will be more than happy to help you out.
    Thanks
    Posted on Jan 12, 2009
    • 6 Answers
    SOURCE: Water level issues on the Whirlpool washer.
    It's overfilling If your washer is overfilling, check these:
    Water-inlet valve
    Water-level switch
    Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
    Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
    It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
    The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
    If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
    Posted on May 08, 2009
    aasc
    • 1606 Answers
    SOURCE: shreiking spin in rinse cycle
    Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
    Posted on Oct 11, 2009
    Testimonial: "Thought it might be a belt rather than the pump."
    Will not rince at end of wash cycle
    If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
    Nov 19, 2012 | Bosch Washing Machines
    During initial startup, will not go into heat cycle - stays in rinse and water is routed to the frother.
    Under the rotary switch on the left there is a micro
    switch which is probably stuck in and it always pressed. That is why you enter
    in RINCE directly and also it repeatedly stays at RINCE position.
    So first you need to check the rotary switch and try
    to slightly pull it out with a thin screwdriver very softly. If this it does
    not make any different you need to replace this rotary switch
    Dec 26, 2010 | Jura Capresso Capresso IMPRESSA C9 One...
    Maytag ensignia makes a great deal of noise during rinse cycle
    "If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
    Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
    Water will not fill during rinse cycle water just keeps runningg?
    That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
    Aug 20, 2010 | Maytag MTW5600TQ Top Load Washer
    The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
    you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
    Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
    Water pressure for Washer (rinse only)
    you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
    Nov 18, 2009 | Kitchen Ranges
    I have a Kenmore washer. the water temp switches by itself.
    IM NOT SURE HOW YOUR WASHER IS SET UP ON TEMP SETTINGS BUT-- THE RINCE CYCLE IS ALWAYS COLD RINCE
    Nov 03, 2009 | Kenmore 24032\24036 Top Load Washer
    LG washer won't move from the rinse cycle. Spins during the wash, but not in the rinse
    If you have correctly selected rince and it doesnt rince, that part of the program is corrupt. Strangely enough, in S.Africa 90% of the washers with rince problems are the lg. Seen quite a few top loaders with this problem as well. There is no reason at all that once rince is selected it shouldnt work, except if faulty.. Only solution is to replace board if rincing to you is essential.
    Sep 25, 2009 | LG WM-1832C Front Load Washer
    Washing machine will fill up with water for the rinse cycle and then it just shuts off.
    if you dont have a soak fascility, then your board is the issue. There is no interlock during the rince cycle to inhibit the machine from running when full. Funny enough, when i find boards have gone faulty, it is often on the rince cycle.(various other brands).
    Sep 15, 2009 | Kenmore Washing Machines
    Lost manual, wheres rince aid comp
    forget the built in rinse aid, it only works for a couple minutes during the whole wash cycle. go out and buy the rinse/aid or jet/dry package that hangs on the racks and works during the whole cycle. of course use only cascade powder soap and sparingly.
    May 27, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    Washing Machines Logo
    20 people viewed this question
    Top Estate Washing Machines Experts
    Dan Webster
    Dan Webster
    dweatherby
    Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
