Question about Car Audio & Video
I have a dual X PR 520 2 channel amplifier that I've replaced 3 times due to this problem it works fine plays nice but after about a month or two it'll start making a popping noise from the speaker not long after that it'll sound like the speakers blown when in fact is not everything is at the professionally and correct and the amp is adjusted properly what else could be the issue?
SOURCE: Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Posted on Jul 09, 2007
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 02, 2008
  • 899 Answers
SOURCE: Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Posted on Nov 03, 2008
blueextc3221
  • 15935 Answers
SOURCE: ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Posted on Dec 22, 2008
SuperTech-11
  • 1591 Answers
SOURCE: When i am turning the power on at. channel 1 for a
Pictures would help a lot (of the circuit board)
You're lucky, you have a whole channel for reference!
This means we can troubleshoot by metering points at channel A and cross referencing them with what's happening on channel B (You'll need a multimeter and SOME skill, as well as a soldering iron, solder, desoldering braid and/or a desoldering pump)
When we find something that's way out of spec, we know we've found the issue, or at least something connected to the issue.
If you have an oscilloscope, we can trace the signal to the point that it stops.
If not, as I said, metering mirrored points should lead to the issue.
Posted on Apr 09, 2011
My dual amplifier has the red light on and my speaker are not playing
one of two things dead shorted speaker in other words blown speaker, or you have an internal problem with the amp due to overheating or overdriving with wrong ohm impedance. shorted transistors hope this helps good luck
May 24, 2010 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Sep 30, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Feb 02, 2009 | Audio Players & Recorders
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Drop out of left channel, Adcom GFA5802
It sounds as if there is a broken solder joint somewhere that slowly opens up with heat. The other possibility is that an input or driver transistor is dying. Since the whole channel is dying, I would guess the broken joint and/or dying transistor are near the very input of the channel.
A tech can very easily find the spot by playing the amp until it starts to die, then spraying small bursts of freeze spray, one component or area at a time, until the amp suddenly comes back to life.
Aug 13, 2008 | Adcom GFA-5802 2-Channel Amplifier
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
Car audio
Product Details and Features PLX-520
Key Features
Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
Other Features
MOSFET Circuitry Yes 3 Way Ready Yes
Dimensions
Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
Mar 31, 2008 | Logic Soundlab PLX-520 Car Audio Amplifier
Dual head unit help!
You can try contacting the manufacturer to see if it can be repaired.
When you have this type of problem, it's generally due to the rotary encoder failing. It's unlikely anyone else will have parts.
Dec 22, 2007 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
