Question about Amana DD01E - DigiDoor Occupancy Sensor For DigiSmart PTAC
How to program the digidoor radio console to motor
How do I program the digi radio console for my digidoor 3 garage motor?
Hi,I have a Digidoor 3 motor & it open & closes as normal but after the garage door is closed it drops the chain about 15cm then slums it back into the track. Can anyone help me out please?
will need a digi door or roller door mechanic in your area
head office ? use contact us
DigiDoor Garage Door Motors Installations Repairs of DigiDoor 1000N...
three motor makes it harder
door drop is 15 cm is not a good thing
chain system needs to be retention ed
motors synchronized
event track may need to be re aligned
Oct 31, 2016 | Building Materials
Who do I contact for Digidoor repairs and maintenance in the Lydenburg area?
only link for digidoors repair
one company
use "contact us " their web page
to get the nearest authorized repairer of didgi doors to the lydenburg region
Oct 14, 2016 | Building Materials
Where can I get a digidoor 1 garage door motor ?
I found a site that you may check out go google -type in www.hydrodoors.co.za/products
they claim to be the home of digidoors. they have an e-mail , sales@digidoor.co.za and a telephone no. 0114749060
even if they are not close to you maybe you can purchase on line and have it sent to you.
Feb 17, 2015 | Cars & Trucks
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
How do I program a Digidoor 3 garage motor.
Limits must be programed. Power down and remove battery power ,press & hold button on motor pc board then apply power still holding button. The door should start running open and close. When it starts you can release button
Oct 31, 2014 | Building Materials
Digidoor ii wall console will not open or close the garage door
First thing to check is the power. If this is on, then the only answer is that your green wire linking console button to the motor has a break in it. I found my break at the motor connection - after time this had been bent and weakened and had snapped. I snipped end of green wire (motor side), cut away plastic and reconnected to motor connection with two arrows up and down, and wa la! Try it.
Mar 11, 2014 | Transcend T-Sonic 850 Digital Media...
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
How do i programme a digi key remote to my digidoor II garage motor, my original fell and no i bought new digi key remote. plz help
How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Apr 22, 2011 | Audio Players & Recorders
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Amana DD01E - DigiDoor Occupancy Sensor For DigiSmart PTAC Logo
282 people viewed this question
Top Amana Home Security Experts
Lawrence Oravetz
Are you an Amana Home Security Expert? Answer questions, earn points and help others
