Question about Dishwashers
Cannot select normal wash - Dishwashers
What does the Acela-wash button do? Why when you select normal or heavy duty cycle the Acela-wash light is on and you can't select other options
Kenmore elite 41072 vs. 41583? Opinions/experience?
ths.gardenweb.com > Home Forums > Laundry Room
Dec 30, 2014 - It is an LG 5.2 cu ft with a different dashboard e.g. Acela wash ... Dideither one of you get the Sears maintenance agreements(warranty)?
Electrolux 70 series....where's Larsi - Home Forums
Jan 8, 2015 - Larsi I know you have one so did you do a review on it that Im missing?... to run a load on Normal/Casual, Acela Wash enabled by default and Steam. ... the temp of the wash by pushing the water temp button while washing?
Jan 15, 2016 | Washing Machines
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Pulsating
If you select the Normal Cycle, twice during the cycleyou will hear the wash motor going on and off at amuch different cadence. The pump will pulse severaltimes, repeatedly turning on for less than a secondand off for 10 seconds. This allows it to drive soils off the filter and into the drain while using very littlewater. If, after selecting the Normal Cycle, you select either the Sanitize or Hi-Temp Wash options your dishwasher will understand that a stronger wash is needed and it will not use this pulsing routine
Jul 25, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
My hotpoint washing machine has a knob to select which programme to wash in. But the knob was stuck and then came off, when I pushed the knob back on, the programmes now seem to be muddled up. For example...
Take the knob off again and look at the back of it. It should be shaped to fit the shaft, like a letter D, it should only go on the one way but is possible it was put back on wrong resulting in the mixed up programs.
Oct 29, 2008 | Washing Machines
Won't start, can't change wash selections
hi there,
can you tell me if you can hear the motor running? if not
did you trip the house breaker? if not
can you open the door? if not
it's the door latch; if yes
is there water on the bottom of the dishwasher? if yes
you are not draining and the dishwasher lost power; if not
the timer is not advancing to the next cycle
let me know.
Sep 28, 2008 | Frigidaire 24 in. FDB679GF Built-in...
Dishwashers Logo
10 people viewed this question
Top Dishwashers Experts
Owen Barnes
