Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Flash drive problems
So lastnight i plugged my 2gb micro drive into my work computer while media player was running i got a pop up for it to sync i just clicked yes and it did its thing started listening to music went out for lunch and had a pop up from media player saying some items could not be played do you want to remove them i clicked yes then i checked later on i went to check my flash drive and it did not show anything on it at all and the led was not turning on... i went home from work plugged in the flash drive led flashed then went off and windows recognized it though it shows it as having nothing on it looked at the storage and it says it has 0 bytes of capacity and 0 bytes used is the drive fried or what is up with it
  • 1,006 Answers
If the flash is not infected with virus so pollow the steps:
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Oct 27, 2007
I dont know how to add the music from my pc to my microsd card
ok put card in computer... then a box my pop up exit off that.. ok go to windows media player.. click the top right button that says sync the drag the music over to it and at the bottom when your done on the right hit sync.. then box pops up and ask where to send hit media card.. it may do this automaticly..
May 13, 2010 | SanDisk 2GB microSD Memory Card
It does not pop up on my computer when i plug it in.
If your micro usb flash drive is not pop meaning that your usb is no longer detected by your computer. I would suggest to you to try to connect that using another computer if ever still the same problem you must contact your sandisk manufacturer or contact your reseller and asked for replacement.
Dec 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sony walkman mp3 flash player
Download MEDIA MONKEY it's 100% better than media player as it will auto sync your player and gives you more options.
Just google it and download for free.
May 13, 2009 | Sony Walkman NWZ-B103F MP3 Player
Can't put music on my microsd card from my windows media player
i can't put music on my micro sd card from my windows or on my pc.
Apr 20, 2009 | Kingston 2GB Secure Digital Memory Card
Does not show songs that were previously synced
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??) 2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer  3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC  4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on). 5. Try other modes as well.
Jan 24, 2009 | SanDisk Sansa m240 MP3 Player
SanDisk 2GB Cruzer Micro: XP doesn't recognise it and asks for drivers
Try these drivers again: <Link>
Also, do a windows update, and download all of the optional updates as well.
Mar 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Device doesn't recognize my 2gb expansion card anymore.
stilts - this player can't actually handle an SD card greater than 256 MB unless the player is largely empty - sad but true
everyone else -
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jan 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
85 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
