Question about Securitron XMS Exit Motion Sensor
XMS seems to have no power, no lights on.
Could xms be blown from power surge or power supply not working properly. can you test power at unit?
What code will pair an i-digital rm-418 universal remote to an xms model xms-1950 DVD player
You can use your remote's code search capability to find something that will work. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
May 31, 2016 | Universal Televison & Video
Does not seem to work with television
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Aug 10, 2012 | Cars & Trucks
Microwave doesn't register it being closed, doesn't work,any ideas?
I have the same problem...manufactured July of 2005. xms -2 Clock works, key pad works, doesn't register door as being shut so it leaves the light on and won't accept a start command.
Feb 05, 2011 | Whirlpool MH1150XM Convection/Microwave...
WD 2500BB is installed in an Xms tv digital recorder But hard drive hums or vibrates and appliance will not work. Can I replace it ?
daferg
Question was this hard drive the one that came with the unit or did you install it your self. Also please let me know the model number of the digital recorder so I can look up info on it.
Issken
http://www.fixya.com/users/issken
Jan 16, 2011 | Western Digital Caviar WD2500BB 250 GB...
Using Corsair XMS Memory 2 1g sticks and works good, tried putting 2 more memory modules to upgrade to 4g and goes into a post loop??
The memory should all match each other (same type). That board should handle up to 16gb using DDR2 1066/800/667 modules, although Win XP can only go to 3Gb.
Apr 27, 2010 | Gigabyte GA-EP45-UD3L Motherboard
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Abit AW8-MAX Motherboard
Need remote code for xms television
Use XLogic code 0726 - just worked for me after YEARS searching!!!
Nov 17, 2008 | Televison & Video
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
New system not booting
Check in the BIOS that your RAM and / or CPU speeds are correct or put them on auto. Choose Default BIOS settings first.
Aug 03, 2007 | Gigabyte GA-M61P-S3 Motherboard
Securitron XMS Exit Motion Sensor Logo
70 people viewed this question
Top Securitron Home Security Experts
Lawrence Oravetz
Are you a Securitron Home Security Expert? Answer questions, earn points and help others
