Question about Sharp Mx-4501n Color Laser - Printer / Copier / Scanner
Why is there a yellow line at the top of the page when I print a document on a Sharp MX-4501N
Bubbabear64
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
tehnik_bdg
  • 91 Answers
SOURCE: Sharp printer copier MX 4501N, how to remove the
Pull the paper tray to the front, after it is stuck pull it up ward and front
Posted on Apr 16, 2009
SOURCE: Sharp MX-4501N Mac drivers 1.1
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Posted on Apr 24, 2009
  • 120 Answers
SOURCE: hello i have copier machine sharp mx-450u,with
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
  • 143 Answers
SOURCE: Sharp MX-4501N Error L4-11
L4-11 is a Shift motor trouble in the finisher. First you must repair the problem then Use SIM6-1 to check the operation of the shift motor. Then use SIM30-1 to check the shifter home position
sensor. Check the harness and the connector
between the PCU PWB and the shift motor.
You can clear the code by using SIM 14.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected
item.
Press START key or EXECUTE key to start the simulation
operation.
To cancel the current simulation mode or to change the main
code and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Posted on Sep 01, 2009
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
Yellow lines printing on paper
Check out my youtube video for cleaning the internals, it will probably help get rid of the lines on your Sharp copier.
Oct 23, 2013 | Sharp Mx-4501n Color Laser - Printer /...
Sharp MX-4501n firmware
The firmware is only available from Sharp's service site. Call a local Sharp dealer to upgrade the firmware for you.
If you're in Houston we would be glad to help you out. We have the best copier service in Houston.
Skelton Business Equipment Houston Copiers
Sep 05, 2013 | Sharp Mx-4501n Color Laser - Printer /...
My Mx-4501N Sharp copier whenever i send black it will print well but when i send colour it will jam
You need to have a service call, call a local sharp dealer. There is a dealer locator at www.sharpusa.com
Jun 04, 2013 | Office Equipment & Supplies
Creating user account
Address book and add new or user list and add new.
Feb 28, 2013 | Sharp Mx-4501n 4501...
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
Sharp printer copier MX 4501N, how to remove the top tray to get to a paper jam.
Apr 14, 2009 | Sharp Office Equipment & Supplies
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
Oct 09, 2008 | Sharp Office Equipment & Supplies
Sharp Mx-4501n Color Laser - Printer / Copier / Scanner Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
