Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Leave clutch out it shuts off - Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Engine revs but no acceleration
Clutch plate and pressure plate seem to be too weak to pull the car. Or one of the CV joints is detached from the gear box. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
Car will not accelerate when gas pushed
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
My clutch won't engage 1997 Honda civic
Apr 06, 2013 | 1997 Honda Civic
Start good, Put in gear leave clutch out shuts off. kit stand up
sounds like the kick stand switch is stuck. try shooting some carb cleaner in it to remove gunk. You can verity by checking the switch's continuity with a VOM or just jumping with a paper clip.
May 27, 2011 | 2005 Yamaha TW 200
My a/c only works after driving for a while, then after about 10-20minutes into use it shuts off automaticly, so i turn the switch to off and drive some more and turn the a/c back on and it works only for...
Sounds like the clutch is on its way out.
This diagnosis and repair is annoying and back breaking. First you have to make sure none of the other sensors including ac on/ off switch is not defective. Then you have to leave a meter of the clutch and determine when it happens if there is still B+ going to clutch and it is not responding or is something else( sensor getting hot and shutting system down.Good luck
Jun 14, 2010 | 2002 Dodge Stratus
Toro 216 triple mower . the electric clutch will not switch off leaving the blades in drive all the time . can the clutch be striped down and repaired
the switch where the blades are engaged try to unplug from the back of the switch if the blades are still engaged after you unplug the switch then the clutch is at fault. If the blades disengage and shut off after you unplug the switch then all you need is the switch!! The clutch can be repaired but the parts are very hard to get if you can even find them!
Aug 26, 2009 | Garden
Craftsman model 917.272950 lawn tractor won't start
OPERATOR PRESENCE SYSTEM
Be sure operator presence and interlock
systems are working properly, If your
tractor does not function as described,
repair the problem immediately.
• The engine should not start unless the
clutch/brake pedal is fully depressed
and attachement clutch control is in the
disengaged position.
• When the engine is running, any
attempt by the operator to leave the
seat without first setting the parking
brake should shut off the engine.
• When the engine is running and the
attachment clutch is engaged, any
seat should shut off the engine.
• The attachment clutch should never
operate unless the operator is in the
seat.
Check your seat switch and clutch switch wires be sure that the connection to each switch is making contact and the mechanism that activates the switch is actually activateing them in other words be sure the clutch is pushing the switch in and your seat switch is occupied and be sure all grounding wires a intack
especially from your battery negative to the frame.You also could have a neutral safety switch which requires your transmission to be in neural.
try these things and let us know how we can further help from more of your input.
Jun 08, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 2001 gmc sierra 2wd 5.3 engine starts for 2 seconds and shuts down any help would be great thank you
THERE IS SOMETHING ABOUT THE CLUTCH ON THE SIERRA THAT IF DOUBLE PUSHED DOWN IT ACTS LIKE A CHOKE. CANNOT QUITE REMEMBER. JUST LEAVE IT OUT OF GEAR AND DO NOT PRESS THE CLUTCH. THEY FLOOD. i KNOW THIS SOUNDS STUPID. I HAD ONE ONCE AND AFTER ABOUT SIX MONTHS IT STARTED DOING IT. ITS SOMETHING TO DO WITH THE CLUTCH AND EXCELERATOR AND HOW YOU PRESS THEM. IT MIGHT BE YOU DO NOT TOUCH THE EXCELERATOR AT ALL JUST THE CLUTCH. I CANNOT REMEMBER HAVE A FIDDLE WITH DIFFERENT WAYS OF TRYING TO START THE CAR. CLUTCH DOWN ECCELERATOR DOWN CLUTCH OFF ECCELERATOR OFF. OR EVEN DOUBLE THE CLUTCH TO STOP THE CHOKE. ITS SOMETHING LIKE THAT. PHONE THE DEALER THEY WILL KNOW IN THE WORK SHOP. SAY A SILLY WOMAN SAID IF YOU LIKE. LET ME KNOW.
Mar 25, 2009 | 2002 GMC Sierra 1500
Husqvarna TYH 2248
If it stalls when you let the clutch it can be a problem with carburetor settings.
If idle is too low the engine will shut down when you leave the clutch pedal.
Set carburetor and see how it goes.
Sep 14, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Towing my boat /seems like its slipping/new clutch?
Try having clutch adjusted first, then you will know if clutch has been slipping.
Let me know if this helps. MMP
Jun 15, 2008 | 1987 Ford Bronco II
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
18 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
