Canon ir7095 error code E-830.what to do - Office Equipment & Supplies
  • 41 Answers
SOURCE: Canon Mp 830 Noisey
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
As far as the noise goes (and possibly related to the error code) be sure that your scanner is UNLOCKED...
With the machine turned OFF:
Open the document cover, look on the tray where the glass is -- and then look to the LEFT side of the glass and you will see pictures of an opened lock and a closed lock and a little switch...
Make sure the switch is next to the UNLOCKED position.
WAIT 5 seconds or so and then turn the unit back on.
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 22, 2008
solofixya
  • 34 Answers
SOURCE: canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Posted on Nov 11, 2008
SOURCE: error code 5110 canon mp 830
Replacing the cartridges is the most common problem
Posted on Nov 24, 2008
tunmun
  • 413 Answers
SOURCE: HOW TO FIX ERROR CODE
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Posted on May 11, 2009
bschilz
  • 2049 Answers
SOURCE: I have a error code
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Posted on Oct 16, 2009
How do I fix IR7095 - error E733-0001
A fault is detected by the main controller PCB in the communication between the DC controller PCB and the main controller PCB and the Causes The connector has poor connection. The DC controller PCB is faulty.
Connector, DC controller PCB Is the connection between the connector J1015 on the main controller PCB and the conductor J316 on the DC controlled PCB normal? Correct the connection. YES: Replace the DC controller PCB. or
check and make sure the DIMM is seated firmly
Check any ribbon cables , they always look connected / re set
May 05, 2016 | Canon Office Equipment & Supplies
Canon ir7095 error code E-65
The high voltage output has a fault(primary charging assembly.Remove and than mount primary charging assy.,check for soiling.Disconect and than connectT601,J723 of the high voltage DC PCB.And the last option-replace HV-DC PCB
Oct 22, 2014 | Canon Office Equipment & Supplies
Error code E102-01 for canon ir7095
E102 - A read error has occurred in relation to the laser scanner unit EEPROM data.
theres a good chance that what is needed here is the laser scanner unit has a Beam Detect mirror and sensor and after time gets coated with foreign particles(dust) cleaning these mirrors/sensors will probably allow the unit to work again- this job should only be undertaken by a qualified service personnel, as more damage than good could be caused. if the laser scanner unit appears clean then iut will need replacing.
Jan 16, 2014 | Canon Office Equipment & Supplies
Hello i have a canon 7086 ir7095 error code e000065-0000 can you help me
That means the "Primary Charger" is shorting out. This problem begs for a tech to come out as I can't describe to a layperson how to fix it. You could try this. Go to additional functions, and then select ( I believe it is) Cleaning and Adjustment. Once you have selected this look for "Wire Cleaning". Select it. I can't see the screen in my mind but ....you will need to say yes ....OK......Uh huh... execute.....something like that. This will clean the "wires" which when are very soiled CAN cause this code.
Oct 19, 2013 | Canon 0000A011BA Copier
What is error code E000068-0000 on a canon ir7095 and how do I fix it?
first thing you need to check is the primary assembly & transfer assembly maybe there is a broken corona wire or the primary assembly or the transfer assembly is dirty
Dec 06, 2010 | Canon imageRUNNER 7200 Copier
Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Sep 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp-830 error code 5010
Nov 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon imageRUNNER 7095 copier has the error code E00057a-8003 ..... can you tell me what this means? can we fix it on our end? Let me know as soon as possible because our copier has been down for 3 days....
This Problem occured with a finisher V1/V1L attached to our Canon iR7095.
The staple unit didn'tmove back to it's initial position. After restarting the printer there was a really strange clattering sound coming from the staple unit.
Problem was solved by removing all trapped pages from finisher and copier. Probably you have to restart several times. The system should reset and move the staple unit back to initial position.
Aug 12, 2008 | Office Equipment & Supplies
IR7095 e000019-0000 error
This is the waste toner container and its location.
Jun 24, 2008 | Canon Office Equipment & Supplies
60 people viewed this question
jasbo
jasbo
