Question about Electrolux Vacuums
How do you get the wand hose to work on the el8805 electrolux upright vacuum
  • 15 Answers
SOURCE: vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
Posted on Dec 02, 2007
  • 4 Answers
SOURCE: electrolux oxygen vacuum
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Posted on Nov 07, 2009
  • 4 Answers
SOURCE: Dyson DC 18 Model won't stand upright on it's own
There is a flip lever that locks it in place and redirects the airflow to the hose when you put it in the upright position. It binds, then eventually breaks. I'm not having much luck finding replacement parts to fix mine.
Posted on Dec 02, 2009
  • 8404 Answers
SOURCE: No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
Posted on Dec 11, 2009
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
My upright electrolux vacuum will not suction from the wand. How can I fix this?
HI, it's Jim from Crucial Vacuum!
If your Electrolux vacuum is losing suction from its wand then most likely there is a clog in your vacuums hose.
Stretch out your vacuums hose as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
Another area to check is your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum. Empty your dust filter after every use to promote optimization in your suction.
You can purchase replacement parts for your Electrolux vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=electrolux&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 08, 2015 | Electrolux Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
No suction when using wand on electrolux precision upright
There is a ball valve between the wand hose and the base hose. It can get stuck in the "base" mode, which won't then redirect suction to the wand hose. There is a spring under the cup that the open end of the hose rests in. When you release the wand from the holster with the one-touch quick release, that spring pushes the cup up and turns the ball valve to the wand setting.
  1. Unplug the vacuum.
  2. Using the one-touch quick release, remove the wand from the holster.
  3. Verify that the wand "cup" is indeed in the higher position. Do this by pushing on the bottom of the cup with your finger. It should easily depress.
  4. Remove the wand hose from the main unit using the quick disconnect feature. Put your fingers into the hole and feel to the right. You will feel the closed valve, verifying that it is stuck in "base" mode.
  5. Using a screw driver, insert the tip at the TOP of this valve and gently pry it downward. This shouldn't take much force.
  6. Reassemble the hose wand using the quick connect feature and reholster the wand.
  7. Plug in the unit and verify that the base unit has suction.
  8. Remove the wand from the holster and verify IT has suction.
Jul 27, 2013 | Electrolux EL8807A Precision BrushRoll...
My wand on my canister began to spark and snap and smoke. The element was melting. and now I am stuck with only a working canister. the elememt or electrical hook up is burned up...and I guess I am gonna...
How's the hose?
If it's only one wand, yes, you'll need to buy a new one. It depends on where it burnt out. If it was at a connection to the hose, the other wand, or the power nozzle, you need to check the connections thoroughly for discoloration, breaks/cracks, and potentially shorts in the hose, wand, and power nozzle.
The entire vacuum should be taken to the nearest Aerus Electrolux dealer for troubleshooting for what caused the sparking in the first place.
http://www.aerushome.com/storelocator/
Jan 09, 2011 | Electrolux Lux 5500 Canister Vacuum
Carpet rollers dont work
Hi There,
Yes, there is a reset switch on your Electrolux. This particular model also has some problems with the wands on the machine as well. Sometimes these wands will short out, preventing the power nozzle from working.
Try pushing the reset switch first to see if this fixes your problem. The reset switch is located on the power nozzle on the right hand side if you're looking down on it. It will be a little red pole, simply push this pole downwards, possible using a ball point pen is the easiest way.
If this didn't fix your problem, then it could be a few different things. The wands on your model are problematic, and should be the next thing that you test. Simply remove the wands from the power nozzle, and you can use a simply electrical tester purchased from Home Depot, and put the testers into the female receptacles on the end of each section of wand to ensure that power is getting down to the brush.
It may also be that your hose has gone bad. If you test both wand sections, and no power is getting through, remove both wand sections and test the female electrical connections on the end of the hose handle.
If you're not getting power here, this indicates that your hose has gone bad and needs to be replaced. We do carry all of the hoses for the Electrolux canisters, and most likely have the one for yours in stock. Please feel free to contact me if you need any further help.
Thank you,
Chris Jones
GoVacuum.com
May 13, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Kind regards
Darran
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Electrolux Home Care 60E 6-Piece Deluxe Tool Set
The Eureka part # 60F for the tools ( hose, wands, converter, & attachments). It runs about $20.00.
Nov 20, 2009 | Eureka 1934 Bagged Upright Vacuum
Electrolux oxygen vacuum
Sep 01, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Suction not working in upright
Hi.
You will have A blockage in either the wand or hose, completely remove them from machine the hose unclips at the bottom back of machine,
Now switch machine on with this removed if machine sounds ok then remove the blockage from hose or wand.
If machine still poor suction & noisey with hose & wand removed check the (U) shaped inspection port for blockages.
Let me know how you get on.
http://dysonmanuals.llc.nu/index.htm
May 17, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
75 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
