Wrote with a Sharpie on the wrong side of the disc. Now it is not playing. Is there a way to clean it so the CD is playable again?
5 Suggested Answers
  • 188 Answers
SOURCE: Previous question: played cd (book) now will not dvd
Laserunit defect.
Posted on Jul 29, 2009
lock123
  • 6831 Answers
SOURCE: CD not playable
Hello
It sounds to me like the laser lens itself may be damaged or even broken.
Here is something you can try though, this might just work if the laser lens has some dust particles stuck to it. Just go to your nearest cd shop and buy yourself a laser lens cleaner disc, it is cheap.
Follow the instructions, and if the laser lens itself was dirty, this will help, otherwise the laser lens might be broken, which is a ver common problem, cause you used it for three years now.
Hope this can steer you in the right direction.
Kind regards
Andrea
Posted on Dec 21, 2009
SOURCE: Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Posted on Feb 13, 2012
  • 6771 Answers
SOURCE: DISC FORMATS??will not play some disc
There are some DVD players that will only allow the store bought discs to work on their system, probably due to copy right infridgements.
Posted on May 08, 2012
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
Dec 20, 2017 | Audio Players & Recorders
Why will my CD's not play on my Wave music system?
it might be you need to get a cleaning disc that cleans the laser inside the cd drive.
or it could be the laser it self has gone faulty.
try a cleaning disc first and see how you get on.
Dec 02, 2016 | Televison & Video
How I clean the lens?
There are special cleaning CDs with bristle hair attached.
You moist them with the special supplied liguid and put the cd in to play.As they spin they gently brush the lens and clean off any debris.
Otherwise you have to open the machine to do it manually with a microfibre cloth (GENTLY) and clear alcohol (JUST A DROP)...
Dec 15, 2014 | Bose & Wave& Music System
When I try to play a CD I get an "err" message. Using store-bought CD's, not ones that have been copied. I have the Emerson PD6559BL portable CD player Love this CD player so I hope you...
Extract from your cd player manual:
"This CD player can play normal CDs p/us CD Recordable (CD-R)
and CD Rewriteable (CD-RW) discs. However the playability of CD-RIRW discs
may be affected by the type of software that was used in 'ripping' the tracks from
the original discs and 'burning' the tracks onto the blank media. Playability may
a/so be affected by the quality and condition of the blank media you use for
recording. 100% compatibility cannot be guaranteed, this is nof an indication of
any problems with your player."
So try to burn the disc with another software or buy different CD-r.
You also want to make sure that you Burned the tracks as audio files and not MP3 file, because your player can not read MP3s.
Hope this helps.
May 27, 2011 | Audio Players & Recorders
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Apr 23, 2011 | JVC TH-A9 System
It will not play Dvd Error message says reject Dvd disc may not be playable type. One DVD began to play but kept jumping. Tried multple Dvd a Few fresh out of box
The device does not play.
Ensure that a supported disc is loaded in the player label-side up.
Ensure that the disc's region code matches the player's region code.
Ensure that the disc's rating level does not exceed the player's.
Ensure that the disc is not damaged or too dirty. Clean the disc or try another disc.
Moisture may have condensed inside the player. Remove the disc and leave the player on for
1-2 hours and then try again.
or lense may be dirty, try using a dvd 'head' cleaner. this may help situation, if continues, may be internal issue and need repair.
Oct 17, 2010 | Symphonic WF803 DVD Player/VCR
My recently made music CD will NOT play in our Philips FW-R7. It will play on all our computers and DVD players. The message is "Wrong Disc." Other music CD we've made do play fine in the FW-R7.
This is common with burned cd's they have trouble playing in different sets. Do prerecorder cd's play fine in your philips? If those are having trouble also you could improve it's playability possibly with a cleaning of the opu. Optical pick up.
Jul 17, 2009 | Philips FW-R7 CD Shelf System
Dec 22, 2008 | Bose & Wave& Music System
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
My 14" dvd combi player wont read any disc i put in. The only thing that happens is that the main screen says reading disc then about 1 minute later is says please insert a playable disc. I have tried...
The optics can not read the disc. Try cleaning the lens inside using a cotton swab and alcohol. Also try playing a music CD. If the CD plays but a DVD continues to fail, the opticsl will need to be replaced. Depending upon the specific model, this could cost anywhere from $50-$120.
Dan
May 20, 2008 | Philips Televison & Video
Computers & Internet Logo
David Payne
David Payne
