Question about Garmin GPSMAP 60CSx GPS Receiver
Show I have borrowed a Garmin GPSmap CSx unit from my son and find that it doesn't seem to be working the same way my own identical unit does. There are several differences that I would like help with: 1) "FOUND" does not appear at the bottom of the compass page while I am searching for a geocache. We really would like to see this on his unit. 2) When I select a waypoint and then GOTO, it always calculates, but my own unit doesn't do this. Please explain why one does and the other does not. 3) On my own unit, the compass page always appears next after I press GOTO, but on his we have to press the page button several times. How can we get the compass page to show up first? 4) On the Compass page, we have selected to display 4 data fields, one of which is "Distance to Next". With my own unit, this reflects the distance to the location of the cache that I am searching for, but on his unit, it seems to reflect the distance to the next-closest cache, not the one for which we are searching. Is there a fix for this? I would appreciate any assistance you can give me with these issues. Thank you.
Re: Show
I think that you are probable running two diferent versions of the GPSmap 60CSx's firmware. Go to Garmin ( ) and download the WEB Updater software for free, then you just plug your unit into the PC and let the updater software check the firmware version, then if its out of date the program offers to update it for you. It honestly couldnt be easier.
Posted on Jun 01, 2009
0 characters
3 Points
How to plot my map in this gps
The 60 CSX dosent support custom maps but if you are looking to plan a route or plot waypoints the easiest way is to acquire a copy of Garmins TOPO disks and do all of this on the PC. You can also do this on the unit using " Mark Waypoint".
Hope this helps!
Dec 10, 2010 | Garmin GPSMAP 60CSx GPS Receiver
GPSmap 296 doesn't show any satellite signal
Check that the date shown on the unit is correct. If not, choose autolocate and allow about 10 minutes for the unit to find satellites. If this works, then the internal lithium ion battery is defective.
Jun 02, 2010 | Garmin GPSMAP 295 GPS Receiver
My garmin gps 60 csx hangs midway during operation
Have you updated the unit's software lately? Free unit software updates can be found on Garmin's site. Search for your model as this software is model-specific. There was a new satellite launched in '08 which caused problems for some Garmin units, making some units freeze. The software update fixes this.
Please come back and advise us if this works, and rate our solution. Thank you.
Nov 30, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
On my Garmin GPS maps 60 csx there are no
This happens to about 1% of the units I've sold. Sometimes the GPS antenna software reverts to version 0.00 which of course is nothing. Check in the GPS by going: Menu > Menu > Setup > System > Menu to see the versions installed.
Use Garmin WebUpdater (free from Garmin web site) to reload the software and update if necessary - they bring out updates a few times a year - it's all free and very easy to do using WebUpdater.
Nov 03, 2009 | Garmin GPSMAP 60CSx
60 CSX not acquiring satelites
Go to Garmins site they have a fix for this. When you download the updates for your GPS it will ask you if you want to load another file check mark the box yes and your GPS will work after you do this. It is a common problem.
Sep 23, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Where ican download garmin 60 csx chipset
Download from the below link :-
Jun 19, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Changed batteries in our Garmin 60 CSx
try adjusting backlight controls, also on a bright day try it shaded
Jun 18, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Gps repair service
You find details to get a service in your area on last pages of your user manual.
Jul 12, 2008 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Garmin GPSMap 60 CSx USB Connection
Actually, I just solved the problem myself...
I went to Garmin's driver download site ( and got the latest USB driver (2.2.1) for the 60C. (Although, it appears that that driver pertains to all Garmin products, not just the GPSmap series or the 60C.) Installation instructions are pretty much standard for Windows drivers, so it's easy.
That: a) Garmin requires special USB drivers for their product is finicky (most USB-connectable products just connect automatically using Windows' generic USB driver), and b) my unit -- which had always worked just fine, and suddenly stopped connecting out of the blue -- remains a mystery. Nonetheless, a driver upgrade was the final step that I needed. (Although, I also swapped USB cables and upgraded MapSource, too, so maybe it's some combination of those things.)
Dec 15, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin MAP 60CSx
try calibrating the compass. make sure the battery type is set to the correct type.
Nov 12, 2007 | Garmin GPSMAP 60CSx
Garmin GPSMAP 60CSx GPS Receiver Logo
147 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
