Question about JVC Audio Players & Recorders
Not supported mode hdmi
I am having trouble getting my toshiba bdx 2300 bluray to work on this tv I have a hdmi cable I hook everything up, It starts up the bluray screen and then it go's blank and says not supported why..?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
What make and model of tv are you trying to play your bluray on ?
Posted on Feb 20, 2014
  • Donald Stevens
    Donald Stevens Feb 20, 2014
    Have you had your JVC TV repaired ...if so you might need to do a factory reset of the TV which can only done using a JVC jig remote
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
SOURCE: Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Posted on Feb 10, 2009
  • 176 Answers
SOURCE: Video Issue with Onkyo 606 when trying to watch Cable TV.
When this happens and you just see the input label try to press the power button on the front of the cable box and see if it brings the picture up. If this does produce the picture then it is a good possibility that something is interfering with the remote communicating with the cable box. I don't know if you have it contained in an entertainment center or how you have placed your equipment but if there is glass try to clean it and also wipe down the front of the cable box and make sure there is an unobstructed view of the front of the cable box.
Good Luck.
Posted on Jan 04, 2010
  • 128 Answers
SOURCE: rx-v1900 hdmi hdtv problem
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
Posted on Feb 19, 2010
SOURCE: Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Posted on Mar 22, 2010
Playing bluray through xbox one on toshiba TV
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
Apr 07, 2014 | Toshiba Televison & Video
Phillips 50pfp5332d/37
take it back and exchange it...then you'll know for sure if they are incompatible or TV is on the fritz or a bad sound system
Jan 14, 2014 | Televison & Video
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Jan 12, 2009 | Yamaha RX-V661 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Too many Cables??
Firstly, let me address audio cables. Optical audio is the same (essentially) as a coaxial digital audio cable, just in a different form. Since you just purchased a Bluray player, you'll see an HDMI out on the rear. This is a high definition video and audio cable rolled into one (however it looks like your receiver does not support this). I would recommend running an HDMI cable from the Bluray player right to the TV, then run an optical audio cable (or coaxial digital) from the TV to the receiver. This will give you the best picture on your TV, and the best available sound through your receiver.
Depending on your DVD player and Bluray player, you might want to consider using just the Bluray player for DVD's and Bluray discs. If your plasma supports 1080p (or really anything better than 480i), you would most likely get a better picture out of DVD's since the Bluray player will upconvert the video to the better signal (of course this depends on your exact model of Bluray player). This will help to eliminate some cabling also.
Other than that, you're not going to eliminate much more cabling. If you really want to get tricky with it, pick up some split loom wire management and wrap them up with that. Be sure to run the power and signal wires separately though! Best of luck, and hope this has helped.
Dec 20, 2007 | Audio Players & Recorders
93 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
