Question about PANDIGITAL Office Equipment & Supplies
How to calibrate S8X1100
Following the manuals' directions and after green light starts to blink and the calibrating sheet is quickly inserted the sheet stops after feeding only a short distance through the scanner. The light begins to blink red and the unit shuts off shorty there after.
SOURCE: paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Posted on Oct 28, 2007
  • 6 Answers
SOURCE: both lights blinking
Granny2 - If you just purchased this printer, exchange it for another and if you still have the same problems, take it back again, only switch to an HP product, they have great All-in-One printers that are affordable.
Posted on Jan 03, 2008
itdude4321
  • 13 Answers
SOURCE: Calibration
If the media sensor is positioned correctly and the printer is set for an autocalibration on power up and printhead close a manual calibration is not really needed. However, here is the information that is the easiest way to run a manual calibration.
Manual Calibration
With the printer at a ready state, press the MODE button two times or until the CALIBRATE light comes on.
Press the FEED button.
Once this is complete press the MODE button four (4) times to save these settings.
Posted on Mar 30, 2008
goodgold
  • 389 Answers
SOURCE: How do you calibrate the scanner bulb?
The Calibration of the scanner and calibration of the monitor - a complex process. Prcess requiring special equipment and experienced specialist. Not advantageously buy high-priced equipment for Calibration of its one scanner and monitor. If work high skilled, you it is necessary to return in service for calibration if you want this execute themselves, recommend to build apart monitor on test list, but then on test table by means of regulations adjusting the scanner on colour and density of the scene to build scanner
Posted on Oct 08, 2009
Testimonial: "Thank you for your reply. I've decided that it will be much less expensive in time and materials to just buy a replacement printer."
  • 185 Answers
SOURCE: When calibrating, it onlt feeds a couple labels
Use the Menu system to calibrate, follow the instructions and it should calibrate with New settings. Calibration by setting it to calibrate on head close or bootup only loads factory settings.
Posted on May 04, 2010
What is calibration sheet,and where do i find one?
Hi, the calibration sheet being referred to was sent with the printer, it's a piece of cardboard ( white with one corner missing). Please check the packaging if you still have it, otherwise borrow one from a friend. All the best.
Oct 15, 2014 | Innovative Itns-500 Film, Slide, Photo &...
HP LaserJetM551
Turn printer off and unplug any network or usb cables. Restart printer, if it comes to ready then you may only need to update the firmware on the printer to solve your problem. Go to HP.com and download the current firmware for the 551 and copy it to a USB stick. In the menus on the printer go to Printer maintenance>upgrade firmware and then insert the usb key into the usb slot on top of printer. Screen will show the file that is on the usb key, press ok and wait for process to finish.
Aug 11, 2014 | HP LaserJet M551 M551N Laser Printer - C
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Hi i have just inherited a designjet 430,it is not connect to a computer as yet. i have loaded a roll of paper and ran some tests which seem to work ok except when i press the set up button the media light...
Either: the sheet you loaded is
misaligned.
Realign it again. See the Users Guide
for a short tutorial on loading media.
Or: it is an invalid size.
For supported media sizes, refer to the
Users Guide.
Or: the media lever is lowered.
Raise the lever.
Or: the cover is open when the printer is
initializing.
Lower the cover
These are the trouble shooting suggestions from the HP service manual
May 01, 2011 | HP DesignJet 430 InkJet Printer
My ribbon is coming out with the label. the front spindle is not rolling.
You have to calibrate the printer. It thinks there is no ribbon (thermal mode) so it's not winding the ribbon up. The instructions are on page 11 of the manual -
4.2 Ribbon Sensor Calibration
Note: Please make sure the ribbon is properly installed before doing this calibration.
Please follow the steps below to calibrate the ribbon sensor.
1. Turn the printer power off.
2. Press and hold the FEED button then turn on the printer.
3. The LED will turn orange then blink red 5 times. Release after the first red blink and before the 5rd.
4. If the ribbon is properly installed the light will turn green. If it is not it will turn red and blink.
Nov 02, 2010 | Wasp WPL305 Thermal Label Printer
How do i calibrate the accu green 3000
According to Scott's:
To adjust calibration, do the following: Adjust the micrometer setting to 6. Flip spreader over. Use your foot to squeeze the trigger against the handle. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. To adust alighment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Sep 18, 2010 | Scotts Company Scotts& Accugreeen 3000...
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Calibration
Greetings,
Sorry to hear that you are stuck?
If and when you regain the function of the menu button, you should perform a calibration. It should be done every time you install or replace a printhead. However, you can run a calibration if you are seeing changes in the image quality. Calibration aligns the printheads and performs a nozzle health check to enable high-quality prints.
1 Load the main tray or photo tray with photo paper.  You don't have any photo paper, but it is recommended for calibrations. 2 Press Menu. 3 Scroll down until Calibrate Printer is selected. 4 Press OK. A new screen appears with Print Calibration Page selected. 5 Press Start and follow the instructions on the LCD screen to complete the calibration.
If the stuck condition presists, let us know. Best bet is to call us directly at the 800 421 6699 as our team will be able to get you running quickly.
Talk tol you soon,
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Calibration
Manual Calibration
Mar 07, 2008 | Zebra Stripe S600 Thermal Label Printer
62 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
