Question about Canon imageRunner 7095
Staple unit won't staple top left corner but staples every other corner
SOURCE: Pgm to staple with a Canon ImageRunner 5000
Canon handles it as PJL comments.
Google the string "PJL COMMENT CANPJL"
Posted on Oct 12, 2008
SOURCE: Can't figure out how to reload stapler
I called a repairman to come and fix it. I am not a stupid person and can generally follow instruction and figure something out, but this is the second time this has happened with this machine & this staple cartridge, and why this is so difficult is beyond me. We have a mainternance agreement so I just called to have him come and fix it....again.
Posted on Dec 03, 2008
Adi_Taticu
  • 71 Answers
SOURCE: I want to print a document and have it collated
check in the finisher unit if staple cartridge is not empty
Posted on Oct 03, 2009
  • 5 Answers
SOURCE: How to install staples in Canon ImageRunner 4570
CHECK TO SEE IF YOU HAVE A STAPLE JAMMED IN THE STPLER UNIT FIRST, MOST LIKELY THATS YOUR PROBLEM,GOOD LUCK !!!
Posted on Jan 23, 2010
  • 58 Answers
SOURCE: On our 5070 machine it ran out of staples. When
take out the staple cartridge and in the clear plastic you will see the arrow engraved the white box also has a arrow these two have to overlap each other to open the case it has two little tabs at the bottom press them in might wanna use a pen or something and the top part will pop up just pull it out
Posted on Feb 10, 2010
Replace a staple unit in a di 3510 minolta copier
Sattle stich stapler or the corner stapler.
Corner is inside the machine open the front door turn green knob to bring stapler out then remove the blue/green cart. do not throw a way you will be replace the staple not the whole cart.. Sattle stich is the stapler that make you booklet with to staples in the middle. will be up on top of the finisher but under it same deal do not cast away replace staples only and make sure that you pull out the top section and reseat so the copier knows you replace those staples
May 27, 2014 | Minolta bizhub 250 Black and White Copier
How do I change staples in a bizhub600
Depend on which staples. Saddle stich (example, Church service program with staples in the middle type) or booklet/corner with the staple on the left side or the corner. open finisher pull out the big section to the left side see to blue/green handles rear one is for corner staple which goes the fastest do to being used the most. when you pull them out there is a plastic guide they should follow if they don't line up power off the machine close all door power on machine. the stapler should go to default location which allows the staple cart. to be removed. DO NOT THROW THE CART AWAY!!!! YOU will be replacing the staples in the cart. Once out Push at he bottom pull the top. DO NOT PULL THE WHITE WRAP ON THE NEW STAPLE UNTIL INSTALLED in the cart. Had customer do that staples spilled on the floor customer installed the staples in the wrong direction.
Also be careful the is a tiny black accurator the mite come out keep it that's what tells the copier the staple is installed give to technician to reinstall.
Feb 10, 2014 | Konica Minolta Bizhub 600 750 Image...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Refill staples impega hd111
Place the stapler horizontally in front of you, as though you were going to feed in paper from the right-hand side.
On the left of the stapler you will find the staple strip - the metalic box with two small holes in the top. Push the stable strip to the right and tilt upwards to release it. You should now be able to pull it out to the left.
Remove the staple strip completely, and place the new staples onto the track above the spring.
Re-attach the staple strip by reversing what you did to take it out. The end of the staple strip should sit across the track in the same way as the staples. Be aware that this time there will be more resistance as the staples push against the spring in the staple strip.
Jan 22, 2013 | Office Equipment & Supplies
I tried to staple too many papers together using my Rexel Staple Wizard, now it won't work - any ideas?
open and check the clip from where the pins come out for staple. may be one or two pins are stuck in it.
Dec 15, 2011 | Tools & Hardware - Others
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
How do I change the staples in the bizhub 200?
If you have the finisher pictured above: If the machine is asking for staples, press "Finishing" on the panel then "Add Staples" this will move the staple unit to the front of the finisher. If the machine is not asking for staples but is not stapling paper then you may have a staple jam. To get the staple unit out: Open front door of finisher, Locate green turn wheel (this is horizontal in bottom left of finisher front door and is connected to white gears) turn this green turn wheel and the staple unit will be moved to the front of the finisher. Remove blue staple cartridge and remove the staple jam. After you reinstall the cartridge into the staple unit just close the finisher door and the unit will move back to home position on its own.
May 13, 2010 | Minolta bizhub 200 All-In-One Printer
I need to change staples
Jan 06, 2010 | Minolta bizhub 200 All-In-One Printer
Load Staples in a Canon ImageRunner 2200
First step, have staple cartridge on hand, type J1 for the iR2200.
Open the front cover of the finisher, which is the door directly below the control panel, which opens from left to right.
There's a handle to grab on the front right corner where the paper comes out, pull it out all the way.
This will expose that module's back right corner where the green staple holder handle is.
With thumb and forefinger, reach in, take hold and lift up and pull out the staple case by its green tab.
You'll see "push" on the sides of the staple case, squeeze thumb and forefinger, one on each "push" sign, and the top will spring up, which is the clear plastic case through which you can see a large spring. Pull out the staple cartridge from the back, under the green tab.
Put the new cartridge in with the orange seal tape hanging out the back.
Press down on the spring-loaded case until it clicks into place again.
Remove the orange seal tab by pulling straight back, then down, not at an angle, as you don't want it to break, just to come off.
Holding it by the green tab, lower the staple case back into the finisher until it settles snugly into place.
Hope that helps!
Feb 09, 2009 | Canon imageRUNNER 2870 Copier
Canon imageRunner 7095 Logo
21 people viewed this question
old marine
old marine
