I need master bios password for Fujitsu Siemens lifebook a1220 Notebook
SOURCE: Reset the BIOS password
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it by pressing F9 or F12 and use BIOS / CMOS Tools from it.
SOURCE: bios password reset?
Here is the link to solve your problem.
Reset BIOS password
Good luck in correcting your problem
SOURCE: bios password Fujitsu
Hi
i found this on ebay it may help you
httpcgi.ebay.co.ukBIOS-PASSWORD-RECOVERY-RESET-REMOVAL-PC-LAPTOP-200567780325pt=Laptops_Nov05&hash=item2eb2c573e5
If the link dont work
copy and paste it into your browser it should take you there
good luck
SOURCE: bios password Bios password Fujitsu Siemens
Usually two computers are capable of sharing one operating system considering several conditions. First, both computers have to the have same operating system where one has experienced a malfunction requiring repairs from the other. Second, both computers prior to a clone require capacity checks. Usually the host computer would need available space to create back up before the cloning process begins should any malfunction compromise both devices integrity. Second, the receptacle computer requiring cloning depending on the conditions would require available disk space to contain the entire clone programs. Usually the cause of a computer to require restoration altogether of operating system requires evaluation since most computers only have enough space to contain an operating system with user interface fonts for productivity. Estimate the conditions on the damaged computer to ascertain if an erasure of disk spaces would be required to create spaces. Also, keep in mind that computers would not clone another system of its own if remnants of the master system are recognized as being present on the hard drive disks. The process of freeing the hard disk drives of spaces for cloning is called formatting achievable with some computers. However, the condition of formatting when not possible due to crashed or program compromises may simply require changing a new empty hard drive before the cloning would be made possible. Once the host computer is has the capacity to power an external device it nature either as available disk space to create backup required prior to cloning or usually a system checks to ascertain that the alternate computer has the capacity to receive every data. Alternately, the receptacle computer may have required changes of parts prior to cloning. A mentionable example includes hard disk drives to contain the new programs, also required to have enough space to create backup once the computer cloning is achieved. The next requirements check for cloning is ascertaining the appropriate cable connection that would be bridging the space gaps for data to be transferred. Usually an effective cable has the capacity to be recognized by both devices as measure prior to any cloning communications. Also, an efficient cable should have the most capacity to transmit data at quantities that does not cause malfunctions discussable. For example, the cables capacity may actually be able to transfer data only not capable of transferring every data size requiring transfer. Once the process is began with such a cable, some computers would transfer only what is achievable to the negligence of what is unachievable. However also, cable incapacity to transfer every data would would last several durations during the process o cloning. Simply said, the cables require compatibility to both computers, second an enormous capacity to outperform prevents any malfunction on the cable connections part during the cloning process. The operating system acquired on the retail market is usually in the form of a disk CD that is simply inserted into the computers drive medium from which restoration instructions are generated to achieve user experiences. For example, inserting an operating system disk CD in the drive of the computer should request either repairing the prior existing version on computer or simply replacing the entire system features. Usually, each acquired disk has instructions on the systems reconfiguration as would be termed. Alternative descriptions of the process are restorations, rebooting of installations of systems programs. Important notes to be wearisome about when working with computers operating systems includes software and hardware compatibilities where a change may require alteration of the remaining, else a malfunction response would be likely. For example, the operating system is the command interface of the computer. Each operating system has functionalities where for example, the malfunctioning computer may have been designed for office productivity causing the manufacturer to install the compatible requisite program system for such an experience to be achievable. Especially on a computer that requires every functioning parts recognizable for communications to be achieved during user experiences, a change in one significant part that would achieve computer user expectation may not necessarily equate to every component parts usually functionality prior to replacement parts. Consulting with a computer systems technician to achieve the experience would guarantee an experience of restoration functionalities were the computer user simple retrieves a device at functioning mode soon after repairs are completed. The significance of consulting with experts is several mentionable. First, professional hand tends to perform expectedly on devices. Second, experts are capable of the repairs without gimmicks experienced with alternate persons.
