Question about Drills
Dewalt dw718 field wiring diagram - Drills
3 Suggested Answers
smjdragonfly
  • 79 Answers
SOURCE: How to wire switch for Dewalt DW718 Type 1 mitre saw.
Does the switch not have color words on the back of it? They used to. Go to Dewaltservicenet.com and look up your model number and type number. Wiring diagrams will be found there. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 10865 Answers
SOURCE: Dewalt dw718 heavy sparks at
Hello roman.... there is either excessive wear or carbon build up on the armature. If you can afford to doit time wise, I would remove the motor and have it serviced at an electric motor shop. Joe
Posted on Jan 12, 2011
My Dewalt miter saw DW718 seems frozen. When I squeeze the handle, the blade doesn't move and the motor makes a sound like it's laboring, but stuck.
There's a little black button to press to lock the blade so you can loosen the screw. Did it get stuck in the in position? Can you turn the blade by hand (unplugged of course)?
I believe the 718 has a belt drive. Could the belt be broken and be buckled or twisted in its case preventing any movement?
Was it left out in the weather and did you get water in the bearings?
Dec 30, 2014 | Dewalt Dw718 12" Dual Bevel Sliding...
I replaced switch and still doesn't work
Check your cord & insure you have continuity to & through the switch first.
Second, check the brushes - make sure they are not worn down & that they slide easily down the brush tube to contact the armature. I have had a few of these with bad field windings - the winding breaks off right at the field connector (you will need a meter to test this)
Aug 10, 2014 | Dewalt Dw718 12" Dual Bevel Sliding...
Dw 708 motor wiring
Could you be more specific? What kind of problem is the saw having?
May 17, 2014 | Dewalt 12" Beveling Sliding Compound Miter...
Nee the instruction manual for the dewalt dw718 compound miter
You can grab the manual and any replacement parts or accessories that should of came with it from eReplacementParts.com - They are DeWALTs supplier for manuals, parts, accessories, and tools online.
Apr 11, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
DW718 motor spins the wrong direction. How do I reverse polarity?
was this tool recently repaired? Also check to make sure the blade is installed correctly, Dewalt does not offer wiring diagrams online so I would suggest calling them to see if they can send one as a PDF file to you. But first ensure for proper blade installation and if it has been recently repaired sometimes the field can be installed 180 degree out, also the wiring could be as you think incorrect. I again would call them
Nov 10, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Jun 17, 2009 | Saws
Wobely blade
sounds like the bearing is going out on the blade shaft
Feb 10, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Drills Logo
41 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
