Question about Marantz SR4500 Receiver
MARANTZ SR4500 Can I connect a turntable to this receiver without a pre-amp stage?
5 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: we have a Marantz sr4500,
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.In this case I think that some capacitors are faulty as when the set is put on it charges on to make the amplifier work. Possible fault in the protect circuit or preamp.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Posted on May 11, 2011
  • 6771 Answers
SOURCE: how do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
Posted on Apr 15, 2012
palaboy
  • 5807 Answers
SOURCE: marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Posted on Aug 02, 2012
  • 344 Answers
SOURCE: Marantz NR 1403 & Preamp - Volume cannot be controlled by receiver
The newer surround sound recievers will not work no matter what you try with them the way you have it hool up, they are not design to be useing a turn table on them that has a mgnetic cartridge ,Evan if you buy a phono preamp for it, you are just wasteing your time end money, I was a electronic tech for over 40 years ,Before i retired this summer, End no lots of people who tried to do the same thing your trying to do ,End It would not work,
Posted on Nov 27, 2012
We have a Marantz sr4500, everytime we put it on it makes a Zzzzzz sound and then it turns off with a loud "buk" sound and shows protect on the amp's screen, after few seconds the amp turns...
May 11, 2011 | Marantz SR4500 Receiver
How do you program it without the remote
You can do it by using the arrow keys at the front panel.Study the user manual before that.
Dec 06, 2010 | Marantz SR4500 Receiver
Connected to turn table. having sound problem. At 99, sound hardly audible.
The bose as most all in one systems do not have an inbuilt phono stage. Phono especially MM type have a very low signal and an eq curve that gets altered in the phono stage. Without a phono stage (known as a phon pre amp) you will not get much fun from your turntable. To connect : turntable out - into phono preamp - phono pre amp out into bose line in/aux in
Sep 28, 2010 | Bose Wave Music System CD Shelf System
Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Mar 21, 2010 | Onkyo HT510 Receiver
There is very low sound from turntable to teac
Check out if the earth connections are are good in the jack.
Are you connecting to a dedicated socket for turntables on your amp? Turntables have to have a pre-amp stage (unlike CD/Tape) before they go to the main pre-amp. If the Teac doesn't have a turntable socket, you will need to buy a pre-amp for the turntable.
Jan 20, 2010 | Audio Players & Recorders
The left channel tends not to work intermittently. I have tested the pre-amp and it appears it is from the turntable. One day it might work and the next it will not.
There will be a pre-amp in the turntable too, presumable you have checked the cartridge, and the everything on the turntable for bad connections?
If yes take the base off and check the pre-amp.
Dec 02, 2009 | Marantz Reference TT-15S1 Turntable
Connect a phonograph turntable to a receiver w/o phono connection
you will need a little box called a pre-amp. This hooks up between the turntable and newer receivers without a phono input. A basic explaination & drawing of this type of setup can be found here
http://www.turntableneedles.com/Pre-Amps_c_4.html
Apr 17, 2009 | Audio Players & Recorders
Obstructed ventilation holes?marantz sr4500
if your amp doesnt have air vent fins on the sides you shouldnt have any problems with overheating
Dec 29, 2007 | Marantz SR4500 Receiver
Marantz SR4500 Receiver Logo
103 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
