Goodman aruf303016ca blows out cold air in heat mode
5 Suggested Answers
  • 124 Answers
SOURCE: My air conditioning unit is
90 percent of the time the freon charge is low and lack of freon lessens the amount of compressed heat that can be created and also the amount of heat that can be extracted. hence less cooling and less heating. however the exact same thing can occur when a change over valve gets stuck partially between heat and cool . it then mixes the hot and cold together and you get poor cooling and poor heating. you check it with a gage. fed law requires that you have an epa certification to apply a gage. low pressures in heat and cool on both high and low pressure gages are a sign of low charge. if low pressure and high pressure are close to the same on both gages then a good chance valve is stuck half way between. you can also sometimes check by feel . at the change over valve two lines should be virtually to hot to touch and two should be cold to the touch. one is heating flow and other is cooling flow. if the valve is stuck then temps will be within a few degrees of the same on all. low charge and the hot lines won't be hot hardly .and the cold line s barely cool. look for white frost forming in the heat mode outside at the condensor tubing shortly after you turn on the heat. thats a sign of low charge. good luck.
Posted on Nov 04, 2008
diths_kri
  • 67 Answers
SOURCE: My Heater blows cold air
IGNITE PROBLEM
Posted on Jan 07, 2009
  • 13 Answers
SOURCE: Goodman Dependable 92 blowign cold air only - no heat
blowing cold air on this furnace usualy caused by high limit trip, or flame roll out. the first one, (high limit) is from insf. air flow. (blocked filter,bad zone damper?
The second,(flame roll out) caused by bad heat exchanger,blocked vent.ect.
Posted on Jan 11, 2009
  • 40 Answers
SOURCE: Not heating
I'm a Certified HVAC Technician and have been working in the industry since 1996. I totally agree with Rob. But, I'm a bit confused in that I have read "Problem with Amana Comfort Zone 18M33PCEH Air Conditioner" but then I read "Not heating
Unit works on cooling mode, will not work in heating mode..blows cold air.
Does reversing valve have a seperate coil or built in"
First of all, an AIR CONDITIONER does not have a "REVERSING VALVE" - only a HEAT PUMP has a REVERSING VALVE. If the THERMOSTAT was REPLACED, did the ORIGINAL COLORED WIRES and ORIGINAL TERMINALS get RECORDED onto a piece of paper? It is imperative that the CORRECT COLORED WIRE within the Thermostat is CONNECTED to the "O" which, on MOST HEAT PUMP Thermostats is the REVERSING VALVE and, in MOST cases is the ORANGE wire. In every HEAT PUMP system that my company has installed, I have directed all of my technicians to use the STANDARD wiring COLOR Codes, regardless of WHAT was previously used. That way, when another HVAC Technician is called, he or she can easily troubleshoot and reduce the amount of time spent on the Service Call, thus saving the homeowner $$$ in the long run. Good Luck!!!
Posted on Sep 20, 2012
I have a Goodman CPE30-1AB (Outside heat exchanger), with a Goodman (air blower) as well. Air blows inside, but not cold. Outside unit is not turning on at all. Can you please assist?
check your breaker or fuses at outside unit. verify you have 24 volts feeding outside unit replace outside unit contactor if you have the 24 volts and not starting.
Aug 08, 2015 | Goodman Heating & Cooling
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
Goodman furnace, blowing cold air
Replace termorelay cose it overheating in service centre 12_26_2013_5_48_58_pm.jpg
Dec 06, 2013 | Heating & Cooling
Central heat not blow hot air
you posted in november if it was very cold auxillary heat issue.
Nov 11, 2013 | Goodman Heating & Cooling
Blowing cold air when in heat mode Goodman model AR30-1
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 14, 2011 | Heating & Cooling
Inside fan turns on when outside unit is in defrost mode when heat is selected. This causes it to blow cold air for about 10 to 15 minutes prior to the outside fan starting.
The inside fan will run while the unit is in defrost. The electric heat strips should kick on to help prevent you from feeling this cold air. When the unit is in defrost it is essentially running in the A/C mode. You should make sure the electric heat elements are working then go from there.
Dec 11, 2010 | Goodman PHKJ048-1 Air Conditioner
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Jan 09, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
