Question about Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb
Won't start How do you start blower in cold weather? Leaf blower won't start
4 Suggested Answers
  • 203 Answers
SOURCE: the best way to start cold
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Posted on Nov 01, 2009
  • 110 Answers
SOURCE: My husqvarna 225B leaf blower starts easy when
A few possibilities, first check the tiny little vent hole in the gas cap for a clog.Second, check the fuel filter in the tank. Third, remove the muffler and inspect the piston for scores and that the rings are free, remove ant carbon build up from the exhaust port. If the trouble persists its time to go into the carb, The pump and metering diapgragms will harden over time and loose their elasticity and cause this problem also
  • 81 Answers
SOURCE: husqvarna leaf blower won"t start,changed the plug and gas,now what
As you pull the cord do you feel a thud thud? if not you don't have compresion. However take the carb apart and clean it with carb cleaner it only takes one small peice of **** to cause trouble.Dennis
Posted on Nov 06, 2012
Won,t start in cold weather
Hi Jerold:
I'm guessing it's a 4 cycle gas motor.
That means there will be oil in the bottom end and in cold weather that usually means increased resistance.
Also, gas does not vaporize as easily so it all adds up to hard starting.
My suggestions:
- Check your owners manual and go with the lightest oil for the temp. Probably 10 - 30
- Make sure your spark plug is in very good condition.
- Have the battery fully charged
- If possible, Keep it in a heated garage or pre-heat it before starting.
- A squirt of starter spray into the carb will help however I try to avoid relying on that.
Hope this helps.
Jan 14, 2016 | Garden
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
My leaf blower starts cold but won't start warm
Test for spark when it is warm. You may have a damaged ignition module.
Oct 06, 2014 | Garden
Husqvarna leaf blower won"t start,changed the plug and gas,now what
Nov 06, 2012 | Husqvarna 28CC Handheld BlowerVac
Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Aug 08, 2011 | Poulan Garden
Mower won't start. Toro mower..engine won't turn over. Cleaned sparkplug...checked air filter..weather cool. Followed instructions for cold engine...prime witrh three pushes of the bulb..wnon't even hint...
Something everyone over looks is oil. Did you check the oil? You seemed to mention everything else but. If you have a low oil switch with low oil it will not start
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Homelite bx90 leaf blower: won't run in cold weather
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 15, 2009 | Homelite 'Yard Broom' Leaf Blower
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Will not start
Pull muffler and check for carbon in cylinder port and muffler screen. Check piston and cylinder for scratches.
Mar 18, 2009 | Poulan Garden
Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb Logo
48 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
