E bias error # 60 on duo1300h - Office Equipment & Supplies
Ricoh aficio 2550 code error SC411
Ricoh Aficio 250 Error Codes
Code
SC411
Description
Separation bias error
A separation bias leak signal is detected.
Causes
• High voltage supply board defective • Poor connection of the PCU • Discharge brush defective
Apr 10, 2017 | Ricoh Office Equipment & Supplies
KDS-R60XBR1 AKB circuit fault
AKB is auto kine bias---means a problem related to one of the three picture tubes or the boards connected to each---if it showed in error buffer with a number to the right that is the number of times the error has been detected.
Aug 29, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Do 4-10 devilles need to have the bias adjusted when replacing tubes?
When replacing the two output tubes you should check the voltage at TP26 or either cathode pin of the power output tubes to ground. Set the bias by adjusting pot R82 to 60mv which is 60 ma across the 1 ohm metering resistor. This coresponds to 30 ma per tube. Changing other tubes requires NO adjustment.
Apr 12, 2011 | Fender Hot Rod Deluxe Guitar Combo...
395 code
395 Development output abnormal A development bias leak signal is detected. High voltage output to the development unit exceeded the upper limit (65%) for 60 ms. High voltage supply board defective Poor connection at the development bias terminal Poor connection at the high voltage supply board
if you change the developer and initialize'it it should work,if not do the above.
Jun 29, 2010 | Ricoh Aficio 1045 Black and White Copier
395 Code in 1035????
Jun 18, 2010 | Ricoh Aficio 1035 Copier
Green lines up and down
Green slanted lines from left to right, especially visible on blank or dark picture is CRT bias circuits problem.
Apr 12, 2010 | Philips 60PP9352 60" Rear Projection...
Error code sc490 on aficio sp c410dn
SC490 High Voltage Power High voltage output error Error signal is detected for 10 times consecutively. One of the DC bias outputs for each PCU is shorted or one of the transfer belt bias outputs for [Y], [M] and [C]. • Power leaking • Defective connection • Disconnected cable • Defective PCU • Defective High Voltage Power 1 1. Replace the High Voltage Power 1. 2. Reset the cables and components. 3. Replace the PCU.
Feb 11, 2010 | Ricoh Aficio SP C410DN Laser Printer
Dell 3100cn
the BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
Jul 23, 2009 | Dell 3100cn Laser Printer
INFO
Get a new HDD for the SC 360
and connect the Exaust fan for the SC490 might be disconnected.
Both in the back of the machine.
Nov 10, 2008 | Ricoh Aficio 450 Copier
Convergence problem.
This denotes that the convergence amps are going bad or the biasing resistors are failing. Check the bias voltages on the amplifiers to determine if this is indeed the problem. If it is try to replace the biasing resistors first, then if this does not clear up the problem, replace the convergence amplifiers. Also check the convergence coils for problems.
I hope this helps,
Thank you,
Shuttle83
Jan 22, 2008 | Mitsubishi VS-60805 60" Rear Projection...
135 people viewed this question
k24674
jasbo
jasbo
