Question about GE Coffee Makers & Espresso Machines
Cleaning inside tank
What can I use to clean the inside of my coffee maker tank? Vinegar? model # 898677
    Problem Solver:
  • 17 Answers
Putting vinegar in the tank OCCASIONALLY wil help to keep the tank and associated tubes clean, but it shold be noted that doing this too often will corrode the aluminum tubing used in the coffee maker. put about a cup and 11/2 of vinegar in the tank and run the coffee maker, followed bu a double run of pure water to clean out the vinegar. should only be done about once a year as vinegar is a mild acid.
Posted on Feb 12, 2015
SOURCE: Brewstation
There is a very fine screen on the outlet of the carafe that becomes plugged over time with fine coffee grounds. You can see it if you look down inside the pot above where the coffee comes out. Just using coffee pot cleaner won't clean it, because it's fine coffee grounds stuck in the screen, that are slowing the coffee going through it.
It's not easy to reach, so you'll a pair of needle nose pliers. Get ahold of the plastic ridge the runs across the top of it and it pops right out. You can use the bristles of an old toothbrush to scrub it. The bristles will fit in the spaces of the fine screen and force the deposits out. You can probably just leave the screen out altogether, it's just there to stop grounds.
Posted on Mar 08, 2008
Wasprey
SOURCE: GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Posted on Dec 28, 2008
  • 4 Answers
SOURCE: how do i use cleaning cycle on ge self cleaning coffee pot
You can find the instructions in this pdf file the link is http://www.gehousewares.com/products/200836153329360.pdf
Posted on Mar 09, 2009
  • 8 Answers
SOURCE: algae in Braun coffee maker float tube
Use a mix of 50% laundry bleach and 50% water.
Half fill the tank and let it soak for several hours.
Rinse tank and refill with fresh water only.
NEVER RUN BLEACH THROUGH THE MACHINE.
Posted on Jun 24, 2009
Cuisinexpert
  • 61 Answers
SOURCE: DCC-1200 coffeemaker cleaning button flashes
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Posted on Aug 21, 2009
What do I use to clean the inside of my tank
The white film is just mineral (lime) build up, but indicates the whole machine may also have buildup. You can try brewing some plain water with a cup of vinegar added, or get one of the commercial coffee maker cleaning products sold at supermarkets.
The film at the very top, visible in the grate, isn't likely to be affected by either cleaning method because the water just passes right through it. For that part, try some full strength vinegar on a cleaning cloth.
Oct 03, 2014 | Bunn 10 Cup Home Coffee Brewer
How to clean keurig coffee maker
It might be time to clean your keurig. Fill the water tank with vinegar and run through about 5-6 glasses leaving time in between to let the vinegar clean. After running all of the vinegar through it should be brewing regularly again.
Apr 28, 2014 | Keurig B60 Coffee Maker
How can I clean the inside of the tank?
mix a little vinegar in the water and run it through the tank several times like you are making coffee, then run clean water till all the vinegar it out.
Aug 18, 2011 | Bunn VPR Coffee Maker
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    Butter melted into top and down in to water container
    mcdevito75 here, Try to clean your coffee maker by running a decanter full of white vinegar thru the system 2--3 times, then fesh water to rinse out the vinegar. Use a new or clean filter at the beginning of the vinegar treatment and after when you rinse with regular water.
    Jul 07, 2010 | Bunn 10 Cup Home Coffee Brewer
    Coffee has a greasy taste
    You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
    Have a cup on old saw
    Aug 09, 2009 | Bunn VPR Coffee Maker
    How to remove and clean milk out of espresso water tank :-(
    NO the tank is just that a tank and you cant get into it to clean....there are many products for cleaning your coffee pot. Some coffee brewing cleaning products are made by Urnex.Buy mixing a half cup (1/2 cup as i assume espresso meaning a small tank the more vinegar you use the more cycles you'll need to remove) of vinegar with the rest water and brew once or twice 2-3 times or until its right to you.
    May 12, 2009 | DeLonghi Caffe Figaro BCO110 Espresso &...
    Bacon grease in my bunn coffee pot
    Did you let the vinegar mix with the hot water in the tank for 2 hours? If this didn't fix the problem, please call 800-352-2866 with the model and date code and we will be happy to assist you with this problem.
    Mar 29, 2009 | Bunn BCW Coffee Pot and Decanter Warmer
    Coffee Makers & Espresso Machines Logo
    125 people viewed this question
    Top GE Coffee Makers & Espresso Machines Experts
    Joseph Hoffmann
    Tom Chichester
    Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
