Question about Cell Phones
T-mobile error codes REG91 - Cell Phones
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
Error codes...
Is this on WiFi or mobile data? If mobile data contact your cell service provider. If WiFi, try rebooting your router.
Mark
Motorola Support
Mark
Motorola Support
Apr 13, 2014 | Motorola Mobility Moto G 8 GB Black...
Code error for nokia
What is your mobile and model ?
If you forget the security code means it show as code error so for this problem you have to reset your mobile, with the help of the codes you can reset your mobile,
If you use nokia or alcatel mobile means get the reset code from this site Onlinegsmunlock.com , it has the best services for the reset code for your mobile at a safe way........
Oct 17, 2011 | Nokia Cell Phones
I recently changed the security code of my nokia X3-00. Yesterday i changed my mobile's sim card, and now when i turn it on my mobile asks for a new security code. I type my security code which is...
put the first sim on your mobile...but before that follow this steps
* turn off you mobile
* remove battery for an hour
* put it back the turn it on again
* insert the 1st sim that you have made a securitycode,try to change it if its possible
* if success,try to insert the 2nd sim the enter you previous code
if ask for a "new security code" enter 12345 or your previous code
May 31, 2011 | Cell Phones
Secret codes of samsung?
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
samsung mobiles
*#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#
Aug 12, 2010 | Samsung SGH-D900 Cellular Phone
I need to unlock the network lock for samsung sgh l810i
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
May 14, 2010 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
I need to no the unlock code for a samsung e1120
hi try these codes
May 12, 2010 | Cell Phones
I had forgotten my samsung metro 3310 app codes
hi try these codes
May 11, 2010 | Cell Phones
Samsung mobile phone error codes 3d010017
my mobile phone SGH-U708E will shut down without any reason suddenly while making a phone call, it will show the error code"3D010017" after restart it.
Aug 06, 2009 | Samsung SGH-t219 Cellular Phone
Cell Phones Logo
101 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
