Question about OCE Office Equipment & Supplies
OCE 7055 will not print
No error, no noises, no nothing. Acts like it's printing but nothing is on paper. Have toner....can you reset printer even if it is not hooked up to a computer?
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: set paper again/toner again error message
I had this problems and did everything suggested on here. Installed firmware update (which just changed the error message - didn't get rid of it), removed paper, changed size, replaced paper, tried new cartridge. Nothing worked. Finally found a tiny piece of paper that must have been blocking the sensor. It was on the left side near where the power cable is. It was less than an inch square. Got it out with some tweezers and problem solved.
Posted on Dec 31, 2008
  • 49 Answers
SOURCE: dell 1700 laser printer
Call Dell. the 1700 has special reset instructions for resetting the drum count.
Posted on Feb 27, 2009
SOURCE: i am using samsung ml
http://www.fixyourownprinter.com/forums/printer/59558
Posted on Apr 19, 2009
Joed911
  • 4338 Answers
SOURCE: 0501 error on a Oce' 7055
1)0501 is low toner concentration problem
fill new toner and then off and on main switch many time
2)check toner motor.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 18, 2009
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
Mar 09, 2012 | Office Equipment & Supplies
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Have oce 7055 but its keps saying out of toner even after it has been replaced.
Restart the printer and put it to the calibration mode. Hope this will help
Aug 26, 2011 | Office Equipment & Supplies
Thanks, Joe
Jun 18, 2009 | Office Equipment & Supplies
Put wrong toner in machine now prints are black
There is only one way to solve the problem. Call a oce service rep. to come out and have them vac. out all of the wrong toner out of the hopper & developer unit and give the bill to the person that put the wrong toner in to begin with.. Good Luck...
May 27, 2009 | OCE Office Equipment & Supplies
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Oct 16, 2008 | Office Equipment & Supplies
Printer not responding after a jam
http://files.oce.com/nl/download/printers/PP20D%20Operation%20Guide%20(Engelstalig).pdf Here is the link to the pdf manual for the printer. They show some light sequences and mention something about the old toner cartridge may need to be emptied/replaced. I'll let you know if I think of anything else. Tim
Jan 29, 2007 | Kyocera Mita FS-1020D Laser Printer
35 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
