Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Malfunction detected, please call Tech Rep. C8103
  • Konica Minolta Master
  • 6,161 Answers
There is a 8301 but no 8103 for a Bizhub 350
Posted on Jan 18, 2016
SOURCE: Error Message C-2253
caution: machine trouble, service call c0500 i'm using bizhub 160
Posted on Dec 10, 2008
  • 7 Answers
SOURCE: Malfunction detected, please call Tech Rep. C3451
Here's the reset procedure.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
And yes, a power outage could cause this.
Posted on Jul 13, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: We have a Konica Minolta
C0920 as per the Minolta Factory Service manual is caused by a tray 1 lift motor failure. In my experience with this code, it is usually caused by paper loading in the tray or something jamming the tray. Best solution is to remove all paper from the tray. Leave the tray open an inch or 2 and turn the main power switch off then back on. The main power is on the back of the machine NOT the one on the right edge of the operation panel. Once the code has been cleared then try a test copy by using one of the remaining trays. If it works correctly then re supply paper into the top tray 1 and then see if the code returns. If it does then either your lift motor is bad or you have something jamming up the lift plate in the paper tray. You can always leave that tray open and run the machine until you can get someone out to look at it. Most of the time tho, reloading the paper in the tray will solve the code.
Good Luck and Thank You for using Fixya
WheatlandServices
Posted on Dec 16, 2010
  • 7 Answers
SOURCE: Bizhub 350 Error CD004
CD004 "failed to overwrite" error? This worked for me. I am not sure how complete the overwrite was but it blanked out all the addresses that used to show on the test sheet.
I tried the 35 hour(!) "overwrite" function but it kept getting CD004 error. This process allowed me to unlock printing function again and wipe the HD.
go to Service Mode (hit these buttons: utility/counters>details>stop>0>0>stop>0>1>Password:00000000>end
go to System Input, turn HD to NO, hit END, home screen will show "failed to overwrite data" again, turn main power switch off for 10 seconds and then turn it on again, home screen should show "all data overwritten"
Go to utility>admin management>Password:12345678>Format hard drive> Format is complete> turn main power off for ten seconds and then on again
Print function should be restored. Go into System Mode again and turn the hard drive back to YES/ON
Posted on Jan 14, 2011
  • 6771 Answers
SOURCE: The screen reads Malfunction Detected C-0060 How
This will require a service technician to address the problem, the self diagnostics is telling you it has a part failure.
Posted on Feb 08, 2011
Di550 error code
1. Run "Hard Disk Format" selected in the following sequence: Tech. Rep.
Mode  Function  Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
service mode :meter count, stop 00 stop 01
Jan 22, 2014 | Konica Minolta Office Equipment & Supplies
Bill is detected
I looked through the service manual for this and I see "tech rep mode" listed. I don't think you can access this from your digital screen, but look for it. Other than that it suggested opening the "front door" and closing it again with the power on to reset. Hope this helps. If you manage to access the Tech Rep mode, there is a button to press to reset the machine...
Nov 06, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Cant access tech rep mode
Hi TECH REP MODE IS NOT 12345678 0R 00000000 THESE ARE TO GET INTO ADMINISTRATOR PASSWORDS TO GET INTO ADMIN TO GET INTO TECH REP MODE YOU HAVE TO PRESS UTILITY KEY METER ON DISPLAY DETAILS THEN STOP 00 STOP 01 IN THIS ORDER ONE AFTER THE OTHER THIS WILL TAKE YOU INTO TECH REP MODE...
HOWEVER THIS MODE IS FOR TRAINED CERTIFIED TECHNICIANS ONLY AND IS NOT FOR USE BY HAVE A GO DIY PEOPLE ENTERING INTO THE TECH REP MODE MAY CAUSE DAMAGE BEYOND REPAIR TO NO CERTIFIED TECHNICANS YOU HAVE BEEN WARNED GET TRAINED FIRST
Dec 12, 2011 | Minolta bizhub 350 Black and White Copier
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
C2253: Color PC Drum Motor’s failure to turn
try to turn these IU's manually, and reset the error, sometimes helps, because usually motors works fine. also you may try to change IUs
Oct 29, 2008 | Konica Minolta bizhub C250 All-In-One...
Error c12c0 in minolta di 550
C12CX (X is any value) deals with the hard drive
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Oct 28, 2008 | Konica Minolta DiALTA Di200 Copier
Error c12co in minolta di550
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
