Question about AOC 2236VW Monitor
How do I do a Factory reset on an AOC 2236Vw Monitor
The screen is faded white. I want to do a factory reset but none of the icons in the menu seem to have the desired effect.
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
SOURCE: the menu is always pop up
so what is the best solution guys?
Posted on Jul 27, 2009
  • 86 Answers
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Posted on Aug 29, 2009
SOURCE: I have an AOC 771S 17
change the 4 tactile switches with new ones better is a sony brand switch.
Posted on Sep 01, 2010
benwabnick
  • 2404 Answers
SOURCE: (external monitor AOC LM765 flickers white
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
Posted on May 15, 2011
Aoc led monitor has a vertical jitter seen on letter and picture
Unplug the monitor from the back of the computer and wait a few seconds until it displays a message "No signal." If the no signal message also has vertical lines, you know the problem is in the monitor and not in your computer. Press the "Menu" button on the screen and then use the other buttons to browse for a "Factory Settings" mode. Select this mode to reset the monitor to its original settings. If the lines persist, the monitor may have been dropped or exposed to a magnet -- which can't be fixed.
Aug 18, 2017 | AOC Computers & Internet
Padlock icon
Many monitors have an on-screen display lock (the padlock icon) that seems to get stuck.
Various suggestions in the links below - the one that seems to work most often is to hold the monitor's menu button down for 15-20 seconds to get the screen menu, then either try unlocking the OSD (On Screen Display) or do a factory reset on the monitor.
http://www.fixya.com/support/t448684-flashing_padlock_icon_in_middle_screen
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Different monitors have slightly different menus, but if it's a Dell monitor you can find the manual below (under Display):
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~cat=3
Jul 07, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
How do I perform hard reset for AOC monitor. Menu reset doesn't fix problem.
There are only two types of resets. Factory reset, and Hard reset. To make a hard reset, you have to unplug the TV from AC mains wall socket, and re-plug it back after 20 minutes or so. Within this time it might have been resetted. To do a Factory reset, you have to enter its service mode option. Electro help . Try this link to know more. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 07, 2014 | AOC L24H898 24 in. LCD TV
Color problem with AOC TV
Try this to reset your monitor back to factory settings:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Jan 06, 2014 | AOC Televison & Video
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
Oct 22, 2013 | AOC 917Sw 19" LCD Monitor
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
I have an AOC 2236Vw monitor that is 3 1/2 months old. Just had to svc it under wty because display would go black a few seconds after power on. They did fix problem by replacing power board inside the...
I would call the support line and ask that they replace the entire monitor with a new one. If you have already had it serviced once, it may be a faulty monitor. Not too much else that you can do without coming out of pocket, which I am sure you do not want to do being that the monitor isn't even 6 mos old. Hope this helps out some, I know these things are a hassle but in the long run it would be to your benefit to have the monitor replaced while it is still under warranty.
Oct 17, 2010 | AOC 2236VW Monitor
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
Dell E177FP monitor won't turn off in power saving mode
I had the same problem and I went to the first button on the monitor to the left(main menu) then with the button to the right (-) I scrolled down to factory reset. I also did the osd setting and I'm not sure what fixed it, but I havn't had the problem sence.
Jan 05, 2009 | Dell E177FP LCD Monitor
AOC color Monitor 7G1R
Where are your buttons located on your monitor? If you press menu there should be a reset option.
Jan 06, 2008 | Gateway FPD2275W LCD Monitor
AOC 2236VW Monitor Logo
156 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
