Question about Panasonic KXTG4772B KX-TG4772B KX TG4772B Corded/Cordle
Earpiece has no sound
Its a SC530 and the mount light show that earpiece is charged yet I have no sound at all.
How do i get the red light to show that the earpiece is charging
Do you have a spare cable to try charging it with?
Apr 17, 2016 | Radio Communications
Services call sc530
Sir please tell me
Canon IR 5870c
how to remove this error code E000748-4000
my Email: snowman587@yahoo.com
Feb 24, 2014 | Ricoh Aficio CL1000N Printer
My earpiece wont charge i just opened the box and the blue light flickers once and it wont charge
Your charger could be bad. Headsets do not usually show any sign they are charging. Leave it for 2 hours on charge then check the charge level as it shows in the owner's manual.
Mar 30, 2010 | Jabra BT250 Consumer Headset
Unit(POCKETALKER) WILL SHOW LIGHT THAT IS ON,BATTERIES CHECKED AS GOOD BUT NO SOUND; INCLUDING BLOWING ON UNIT.
If you do not hear anything, such as hiss, buzz or static, then you headset or earpiece is bad. Recommend a new headset or earpiece.
Mar 11, 2010 | Williams Sound PKT D1 H21 Pocketalker...
This is the second Plantronics earpiece that stopped working
I am sorry to say but the Plantronics are cheap and not well made. Sounds like you might have a weak battery and because of that it wont have enough charge to turn on. I myself have gone through many and now spent a little bit more and got a better earpiece.
Sep 08, 2009 | Plantronics Explorer 220 Bluetooth Headset...
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
Battery Light Won't Go Solid. Lot's of clicking sounds and lights flashing (GN Netcom 9120).
It sounds like it may be a defective unit in that the charging points on the base and the earpiece are making intermittant contact, hence the clicking noise you get when the unit goes into headset mode and the fact that the battery never reaches a fully charged status.
A couple of things to try:
  • Check the charging points/contacts on the base and the earpiece for damage.
  • If they look ok, gently clean them with some spirits and try again.
Nov 07, 2008 | GN Netcom GN 9120 Professional Headset
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
Panasonic KXTG4772B KX-TG4772B KX TG4772B Corded/Cordle Logo
19 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
