Question about Lands Phones
My clear one max conference phone does not ring. It's not on mute and the ringer is on
jncayo
  • 31 Answers
SOURCE: How do you mute a conference call?
to mute while you are on a conference call, the has to be on speaker then push the mic buttonto turn it off.
Posted on Oct 11, 2008
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
ynotphone
  • 192 Answers
SOURCE: Put Phone on Mute while on conference call
The button for handsfree is the same button for Mute.
So when you are on the handsfree call, press the handsfree button again and the call is muted on your side.
To talk again, press the handsfree button to un-mute the call, then press it again to mute your call.
To hang up press the orange RLS button.
Posted on Apr 22, 2009
stwill2326
  • 77 Answers
SOURCE: No mute - conference calls
sounds as if you will need your vendor to program your phone and others that need be to have Handsfree/mute capabilities.. i assume since you can not mute then you can not place your phone on Handsfree either.
Posted on May 29, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Posted on Dec 18, 2009
My phone stopped ringing
You may have turned your volume very low or you may have muted your phone (turned off the ringer). Check your volume and ringer settings.
Jun 24, 2014 | Kyocera Cell Phones
Doesnt ring when call transfered
When the Polycom is on-hook (not in a call), use the volume rocker to change the volume of the ringer.
Dec 10, 2013 | Polycom VoiceStation 300 (220017910001)...
How to make the ringer on motorola L70xM louder
menu settings ringer volume up button until max is reached
Aug 27, 2013 | Motorola Mobility Additional DECT 6...
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
The phone won't ring. How do I make it ring? I have gone to settings, sounds, ringer and alerts. When I click on that, the phone makes a ringing sound, but when calls come in, it is silent. Please...
Have you checked the switch on the top left of the phone?
That's the mute switch. Flip it in the Up position and that should fix your problem
If the phones ringing when you test the ringer in the settings, the ringer works. It's probably just muted..
I hope that helps...
Thank you
Aug 25, 2011 | Apple iPhone Smartphone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How to put phone so when phone rings, cannot hear it
Press MENU/SELECT to display menu when in idle mode
Press Up or Down arrow to reach SETUP HS. Press MENU/SELECT.
Press Up or Down arrow to reach RING VOLUME. Press MENU/SELECT.
Press Down arrow all the way down, then Press MENU/SELECT to confirm.
A ringer off icon (Bell with a line through it) will be displayed on the screen.
Note: While the phone is ringing, you can temporarily silence the ringer by pressing OFF/CLEAR or MUTE/REMOVE. The next call will ring normally.
Rest of Manual details here: http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
Jan 14, 2010 | Vtech Cordless 6041 Phone
How can I mute a cell phone call
While the call is active, push the left button for options and scroll to mute.
Jan 06, 2009 | Nokia 6085 Cellular Phone
It doesn't ring
I had the same problem. If the phone is plugged into an outlet with any other device, the phone may stop ringing until you plug into an electrical outlet where it is the ONLY device using that outlet. This has worked for me
Dec 30, 2007 | GE 28112EE2 Cordless Phone
Lands Phones Logo
53 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
