Question about KitchenAid Mixer Accolade 400 Wire Whip Kitchen Aid Stand Mixer Part K45WW
Accolade 400 wire whisk does not fit bowl
Wire whisk does not fit 5qt bowl
3 Suggested Answers
defrankond
  • 65 Answers
SOURCE: Hi Guys, here's my problem
ok firstly if you have a stand mixer with the lift bowl you have to put a dime on the side of the bowl at the base and see how much clearence is needed to be taken away. if the dime gets moved the mixer is ok. if not take off the flat beater, take out the bowl, and look at the back of the stand. just below the motor about 2 inches you will see a screw. turn it to the left a quarter of a turn. dont over adjust do it slowly. if you have the one that you tilt the head back on do the same thing with the screw up to you get to the adjusting part. the screw will be in a different spot on those mixers. it is located in the neck of the mixer. it is right in the area that tilts back. the dime shouldnt fly around the bowl it should just gently get tapped. and never use the wisk when adjusting always use the flat attachment. and always adjust slowly never over adjust.
Posted on May 05, 2008
defrankond
  • 65 Answers
SOURCE: KitchenAid Countertop Food Mixer
KitchenAid ACCOLADE 400 Mixer.When mixing dough the bowl jumps out of the the bowl lock. How can this problem be resolved?
I know this sounds a bit simple but the bowl cup can sometimes actually wear out and a very fast (# screws) and a new one and the problem is solved. If however there is a problem on the head hold down set screw (under the mixer in the cavity ) it can come loose then the mixer head can bounce all over the place causung the bowl to get loose in the holding cup at the base of the mixer., I hope this helps, let us know if you need more, we can FixYa
Feb 22, 2015 | KitchenAid Food Mixers
KitchenAid ACCOLADE 400 Mixer. When mixing dough the bowl jumps out of the bowl lock. How do in resolve this problem?
Make sure that the bowl is fully tightened in the bowl lock. If this does not solve the problem it may be that the lock disc itself needs to be replaced or that the amount of dough is more than the dough hook can handle.
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
Can a K4-b model be fitted with a K45 bowl?
No, it can not. I have the same k4b mixer and ive been researching the very same question as the k4b bowl is hard to find. The problem is that the k4b uses a small threaded mount stub centered at the bottom of the bowl and the newer design uses a much larger recessed well which is threaded to accept the threads on the bottom of the K45 bowl. Im thinking I might cut the base of the k4b and fit the bowl mount hardware pt no. w10191926 and use the paddle, whisk and dough hook designed for the K45 bowls shape.
May 14, 2012 | KitchenAid K45SS Classic Stand Mixer
I need a replacement bowl for the braun km32 mixer
I have an extra bowl, but am in need of a regular whisk...any chance you have an extra and we can trade?
Jun 21, 2010 | Braun Food Mixers
Trying to locate a wire whisk for my Hobart D-340
Bill. Whisks are not interchangable for different bowls. Try ebay to locate one.
If this solution has assisted you, please rate it. ricardok45
Mar 20, 2009 | Hobart D340-6009 Mixer
KitchenAid Mixer Accolade 400 Wire Whip Kitchen Aid Stand Mixer Part K45WW Logo
26 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
