Question about Brother PC-420
Safety device has been activated
New machine, sewed one quilt, moved on to curtains and it went kablooey. 30 years sewing experience. took out bobbin casing, cleaned, still activating
5 Suggested Answers
  • 323 Answers
SOURCE: Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Posted on Jun 18, 2008
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
  • 52 Answers
SOURCE: Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
Posted on Jun 25, 2009
chrismyers67
  • 53 Answers
SOURCE: I have a CE-4000 model. In the middle of sewing,
When you put back in the bobbin case, there is a little "knub" that sticks out with a flat spot on the right (on the top side of it) that you need to ensure it rests gently to the left of the position finger bracket (silver metal piece, in the square of the bobbin case area its on the right closest to you).
When you put in initially, it was probably twisted clockwise and there was a gap between the knub and the position finger bracket and when you put the needle plate on in jams that bobbin case in that position and the needle just takes chunks out of it..
You might need a new bobbin case, try sanding out the needle marks with sandpaper.
-Chirs
Posted on Jun 06, 2010
I have a bernina 550. What should I set the tension when sewing with invisible thread?
When I took a quilting class, the instructor had us put the invisible thread spool in a coffee cup behind the machine. Then we taped a paperclip or safety pin at the top-back of the machine (with about half of it above the sewing machine) between the spool pin and the first thread guide. Then we ran the invisible thread through the hole in the paperclip/safety pin and through the remaining thread guides and tension disks. (Technically, we avoided the spool pin.) Do NOT put invisible thread on the bobbin. Then adjust the top tension like you would for regular quilting or sewing.
Aug 07, 2017 | Bernina Sewing Machines
Safety device been activated. baby lock elegant 2
When a safety issue has been activated, it generally means that it should be taken to a technician. In other words, the machine has a fault that prevents it from functioning for the safety of the user.
Dec 26, 2016 | Baby Lock Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Learn How to Free Motion Quilt Stippling
Oct 31, 2016 | Janome Sewing Machines
Is there a setting to quilt freehand?
Are you asking about free motion quilting (FMQ)?
If so, you need a darning foot of some type (a foot that does not press the fabric to the sewing surface).
You need to drop the feed dogs (or if your machine does not have that capability, a feed dog cover that probably came with your machine and set the stitch length to zero).
Then, add lots of PRACTICE!!! I like to draw designs on a white board with an erasable white board marker... The more fluid you can become, the better experience you will have with FMQ.
Free Motion Quilting Beginner Tutorial 1 of 4
START HERE
Sep 29, 2016 | Sewing Machines
The safety device has been activated
Turn off the power supply and open the needle plate.
Remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any lint or thread that may have accumulated during use.
If the problem continues, the machine will need to be serviced by a Brother dealer.
Mar 03, 2010 | Brother SE-270D Computerized Sewing...
Jun 24, 2009 | Brother SE-270D Computerized Sewing...
When machine quilting sews fine when moving forward, skips stitches when moving away
Check your needle. Make sure it is not blunt, try a Size 90 Topstitch needle or Embroidery needle. If you are using a thread thicker than regular piecing weight, you need a needle with a larger eye and a larger scrarf - the hollowed out bit at the back of the needle. Also don't sew too fast nor change direction too sharply. If you need to do a sharp turn, let the machine "mark time" once at the turn before moving off in the new direction.
Pam
Apr 28, 2009 | Sewing Machines
Sewing machine stuck on reverse only
The same thing happened to me. I think this machine is just junk!
Feb 17, 2008 | Sewing Machines
Brother PC-420 Logo
16 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
