Question about Citrix GoToMeeting
When viewing others screen with windows 8.1 the screen is very large and can only view a part of the connected computers screen.... Sometimes also is just a black screen
How to Enlarge Thumbnails in Windows Explorer?
Open the libraries folder. Or you can open another folder, such as the pictures, downloads, computer, etc. It doesn't matter which folder you begin on; all the Windows Explorer folders have the same method of enlarging the thumbnails.
Locate the taskbar near the top of the screen. On the upper right side of this, you'll see three icons. The first one on the left side, when rolled over with your cursor, should read "Change your view."
Click on the "Change your view" icon. A small menu will pop up with a list of different ways the Windows Explorer can present itself.
Select "Extra Large Icons". The icons will become large enough for you to see easily.
Repeat for all other Windows Explorer libraries.
Oct 19, 2016 | Computers & Internet
Can't view entire e-mail on screen, too large
Go to control panel and adjust the settings for ease of use or adjust size of screen at bottom of screen . many ways to change it depends on your windows and computer
Mar 02, 2013 | HP Computers & Internet
New computer has windows 8. can't view cameras
You didn't specify the make and model of your camera so I'm assuming it uses a memory card of some type.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Jan 13, 2013 | Cameras
Compaq desk top screen to large
Right click your desktop and click resolution. Adjust it so that it is set to the maximum possible (native) and click apply. If you're talking about metro, you should be able to scroll scroll to reach the other icons. You can also adjust icon screen size if you go to the desktop, hold the control key and scroll using a wheel, or right click and change icon size.
Nov 04, 2012 | Compaq Computers & Internet
When I try to boot up it says windows did not start properly and it just keeps rolling this screen. It flashes to the windows xp for a second and then goes back to the screen saying it did not start...
Try restore pc to factory setting. here is the way : http://support.gateway.com/s/software/microsof/Vista/7515910/7515910su12.shtml
Or follow this without picture is the same info:
Restore from Factory Default
The Factory Default installs a new copy of Windows Vista™ on the computer. The installation restores the computer back to the factory installation of Windows Vista with all the drivers and programs that originally came with the computer.
Notes:
  • Be sure that you back up your data files before performing this option. All of your personal data files and applications are erased during the recovery process.
  • Due to the large number of virus and Spyware threats on the Internet, it is recommended that you disconnect all Internet connections before performing the recovery. After the recovery, antivirus and firewall software can be installed, and then the Internet connection can be re-enabled to update the antivirus definitions and perform Microsoft® Windows Updates.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, press ALT+F10. The easiest method is to hold down the ALT key and repeatedly press the F10 key. Note: There is no prompt to press Alt+F10.
  5. Windows loads files.
    View Picture
  6. The Please wait a moment screen is displayed.
    View Picture
  7. In the Restore from factory default dialog box, click Next.
    View Picture
  8. In the Destination Disk Information dialog box, click Next.
    View Picture
  9. In the Notice dialog box, click OK.
    View Picture
  10. The hard drive partition is created.
    View Picture
  11. The factory default installation is copied to the hard drive.
    View Picture
  12. In the Finished dialog box, click OK.
    View Picture
  13. The Please wait a moment screen is displayed and the computer restarts.
    View Picture
  14. Windows prepares to start for the first time. This may take a few minutes.
    View Picture
  15. Windows continues setting up the computer.
    View Picture
  16. The computer restarts.
  17. In the Set Up Windows screen, click Next.
    View Picture
  18. In the Please read the license terms screen, select the I accept the license terms check box for each item, and then click Next.
    View Picture
  19. In the Choose a user name and picture screen, enter the appropriate information, and then click Next.
    View Picture
  20. In the Type a computer name and choose a desktop background screen, enter the appropriate information, and then click Next.
    View Picture
  21. In the Help protect Windows automatically screen, click Use recommended settings.
    View Picture
  22. In the Review your time and date settings screen, select the appropriate settings, and then click Next.
    View Picture
  23. In the Select your computer's current location screen, click the appropriate option.
    View Picture
  24. In the Thank You screen, click Start.
    View Picture
  25. Windows checks the computers performance. Depending on hardware, this process can take up to 15 minutes to complete.
    View Picture
  26. Windows prepares the desktop.
    View Picture
  27. The Gateway Recovery Management is installed.
    View Picture
  28. Installation is complete.
Dec 23, 2010 | Gateway LT2001u Netbook
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Freezes after 8 secs (No sound or anything)
I registered my Sansa View in sandisk site, and the support sent to me these two solutions. I have a similar problem like you and I'm still haveing problems but meaby these steps working in your sansa view.
regards
Diego
Nr 1:
Let us update your player's firmware:
Step 1 – Connect the player in Recovery Mode.
1. Turn off the player.
2. Slide down the Hold switch along the left side of the player down so the orange is showing.
3. Press and hold the HOME button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer (XP) or Computer (Vista).
5. Release the HOME button.
Download and update the firmware.
1. Download the firmware file:
Click Here for the Sansa View Firmware update file
2. Extract the zip file.
3. Copy the extracted firmware files (*.dat, *.rom, *.mi4, and *.fnt) to the 16MB-FORMAT drive.
4. Disconnect the player. This will now start the firmware update.
5. Slide the Hold switch to the unlock position.
6. Turn on the player.
Nr 2:
It appears that this is caused by file corruption in your player's memory. Usually, formatting your mp3 player resolves this FM issue in your player.
Formatting your Sansa View Mp3 player in Disk Management:
WARNING - FORMATTING YOUR MP3 PLAYER WILL ERASE ALL MEDIA FILES IN YOUR PLAYER, PLEASE BACK UP IF POSSIBLE.
1. Make sure the Sansa View is turned on.
2. Engage the hold switch, located on the left-hand side of the player.
3. Press and hold the LEFT BUTTON ( << )
4. Connect to the computer while pressing and holding the LEFT BUTTON ( << ). Do not let go of the left button until the player is detected as Removable Disk.
5. The Sansa View should now be connected in MSC mode and should appear as a "Removable Disk" or "Sansa View".
6. From the desktop, right click My Computer, then select Manage. If you don't see My Computer on the desktop, click on Start and right click My Computer from there, then select manage.
7. On the Computer Management window, click Disk Management from the left pane.
8. On the right side, locate your sansa device on the list (it might be recognized as removable disc), right click on the sansa device, then select Format.
9. On the Format Window, select FAT32 under File System and make sure that the Quick Format option is not checked.
(You might get a warning window about your files being deleted when you format the device, if that is not an issue for you, click ok.)
10. Click OK to start formatting the device. This should start the format process.
11. Once the formatting is done, unplug the device from the computer. Let the device refresh.
12. We can verify that formatting is successful if it shows no files on the player.
Oct 25, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
I would like sto dump my system, and start over. Syst: Gateway GT5220. running Windows XP service pack 3
this will perform an install that will eraseeverything and start over.
  2. Turn off the computer using the normal Windows shut down process.
  4. Turn on the computer. To start recovery, at the prompt press the F11 key.
    View Picture Note: If this is the first time the computer has been started to the recovery partition, insert the System Restore CD when prompted and then click OK.
    View Picture Files copy.
    View Picture
  5. In the System Restore Options dialog box, select Full System Restore (Destructive), and then click Next.
    View Picture
  6. In the System Restore - Format and Recover dialog box, click Yes.
    View Picture
  7. Files copy.
    View Picture
  8. In the System Restore dialog box, click Restart.
    View Picture
  9. The computer restarts.
  10. Drivers and applications are installed.
    View Picture Note: The following Out of Box Experience (OOBE) screens may vary slightly between models.
  11. In the Welcome to Microsoft Windows screen, click Next.
    View Picture
  12. In the Are your speakers working? screen, click Yes! I can hear the music!, and then click Next.
    View Picture
  13. In the What time zone are you in? screen, select the appropriate time zone, and then click Next.
    View Picture
  14. In the End User License Agreement screen, click Yes I accept for both EULAs, and then click Next.
    View Picture
  15. In the Help protect your PC screen, click Help protect my PC by turning on Automatic Updates now, and then click Next.
    View Picture
  16. In the What's your computer's name screen, type a name for the computer and a description, if desired, and then click Next.
    View Picture
  17. In the What's your Administrator password? screen, type the appropriate information, and then click Next.
    View Picture
  18. In the Is this computer in a domain? screen, click Skip.
  19. The computer checks the Internet connectivity. Please wait.
    View Picture
  20. In the How will this computer connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  21. In the Do you use a username and password to connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  22. In the Setting up a high speed connection screen, select the appropriate options, and then click Next.
    View Picture
  23. In the Ready to register with Microsoft screen, to register with Microsoft after the OOBE screens are completed, select No, not at this time, and then click Next.
    View Picture
  24. In the Thank you screen, click Finish.
    View Picture
  25. Installation is complete. Any application that shipped on a separate CD can now be installed. It is recommended to update the antivirus definitions and perform Windows Updates.
Oct 06, 2008 | Gateway Computers & Internet
Input not supported
Do you get anything on the screen when you first turn on your computer?
If you do the windows resolution somehow got set to high for the screen to handle. To fix this press the F8 key a couple times after the BIOS splash screen goes away ( The screen that has HP or DELL, etc on it). If done at the right time it will bring you to a menu that has several options including safe mode. You'll want to pick " Enable VGA mode." From there it will start to load Windows, but everything on the screen will be large. Once windows is fully loaded find a empty spot on your desktop and right click. From the menu that pops up please select Properties. It will open up a box that says "Display Properties." Click the tab that says Settings. On this tab move the resolution slider to right right a click or two to make the monitor normal size and click apply.
Nov 14, 2007 | View and View Technologies VNV AquaView...
Computers & Internet Logo
Top Citrix Computers & Internet Experts
xxxxxx xxx
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
