Driver for hp cp 4525 usb - Office Equipment & Supplies
Install device driver for targus USB port onto my HP pavilion computer
what PC?, post your service tag data. (1000s of different Pavilions)
Targus makes vast array or gadgets.
which do you have,?
no OS stated (operating system) XP?
make sure the PC has internet connection,
or its hopeless.
plug in the device, here ding dongg. sound.
it fails
so you go to device manager (in CP control panel)
and see the TARGUS device is painted red or yellow
you right click the device, there and pick update ....
bingo it works
or go to targus dot com and get your Driver for unstated device
and get it and load it and its working.
Apr 01, 2017 | HP Computers & Internet
Need driver for ihome optical mouse (IH-BL-M200B) Simple travel corded optical mouse. Won't work on my HP Laptop through any USB ports.
what HP, they have long names
what OS, XP,Vista,w7,w8 ,w10.??? what?
is unstated HP connected to the internet?
must be, or driver can never be found or downloaded
if yes, it will find the driver.
toss coin,land w10
ever been to CP, control panel
and click device manager?
see mice and other pointing devices , sure
see yours ? with red or yell errors marks?
sure
RC right click and and pick update, then let mS find it
be connected to internet or all things dont work are pain to fix.dcb9ef07-ef34-4cad-ab40-44aa5721a6a0.jpg
Feb 06, 2017 | HP Computers & Internet
Sabrent CP-4PTU USB 3.0 4 - Port PCI Express card. p&p installed and computer stops after Win 8.1 logo and rotating dots stop.
did you install the software first,? I know you said it's plug and play, But it also says for Win 7 xp and other operating systems,.
Did you look on web site for drivers?? if not this is the driver listed for your item,.
http://www.sabrent.com/drivers/CP-4PTU/CP-4PTU.zip
Or you can read about your item here..
http://www.sabrent.com/category/controller-cards/CP-4PTU/
Install the driver then shut down system and install your card and reboot the system. Good luck
Sep 15, 2015 | Computers & Internet
How do I fix 58.04 Error on CP 4525
Hi chifundo mtambalika,
I would be happy to help you with your CP4525. I understand you are seeing error 58.04. I found something you may find helpful, please use the following link to take a look:
cp4525 error 58 04
I hope this helps.
I work on behalf of HP.
Jul 03, 2015 | HP COLOUR LASERJET CP4525DN Printer
How can I resolve a problem on Laserjet printer 4525 with an error 49.2fa7?
#The error might be caused by a
network connectivity problem,
such as a bad interface cable, a
bad USB port, or an invalid network
configuration setting.
#The error might be caused by the
print job, such as an invalid printer
driver, a problem with the software
application, or a problem with the
file you are printing.
#Upgrading the product firmware
might help resolve the error. See
the product user guide for more
information.
For upgrading the Firmware. go to hp.com, download the firmware, read the read me file before uploading the firmware...
May 12, 2014 | HP COLOUR LASERJET CP4525DN Printer
Error 49.ff04 for hp cp 3525x
Normally caused by firmware.
This error can be caused by corrupted print
jobs, software applications issues, nonproduct
specific printer drivers, poor-quality
USB or network cables, bad network
connections or incorrect configurations,
invalid firmware operations, or unsupported
accessories.
Power cycle the printer. Try printing from a different application. If the error doesn't come back, it could have been caused by the other application. If it does return and you are sure that your cables(USB or network) are good, you will probably have to upgrade the firmware.
Jun 28, 2011 | HP LaserJet P4015N Printer
Downld file now SEND RFU UPGRADE ON USB DEV PORT
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
Nov 26, 2010 | HP LaserJet 4345mfp Printer
The scroll bar on my HP pavilion zv5000 does not work.
no. not scroll bar.
you are posted that your desired pointing device
is bad,dead, and the do not want the built in device working,
your unnamed MOUSE is bad. right.
ALPS tells us nothing. (is it a GP-410UB " wild guess.
is it USB mouse or PS2? what model mouse? the number.
what OS are you running, we can not guess this... and matters. big time.
there are 2 issues on notebooks, zv5000
1: SHUTTING OFF THE INTERNAL ,POINTING DEVICE(S)
do that in device manager, click unwanted device
and click (right) PICK DISABLE .
it now dead this internal, pointing device.
2nd: option to is click Mouse (CP) and then pick the internal
laptop , mouse, and find a tab there called.
what to do with 2 mice, (on mine it has , USB mouse shuts off internal mouse, not all can do this, my HP8540 you can't but the maker of the notebook pad had and upgrade from this pad, and now has this feature,)
ymmv, your mouse may vary.
2: The mouse external. what ALPS, is it USB or PS2
finding drivers for very old mice can be hard,
did you have internet connections when you plugged in this mouse? if yes, it will attempt to find a driver automatically (PnP magic)
next time say.
a wild example.
Im running Vista OS.
My glidepoint model, GP-410UB does not work right.
help.
the Control panel. 101
has a mouse icon
and a device manager icon
this is your only controls, besides REG hacks.
we can all those, all ways, but you need to tell the helpers, OS, and mouse model first. and if USB
May 25, 2017 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Driver of HP Laserjet CP 1215 Printer needed for MAC machine
HP does not currently have software or driver downloads available for your product for that operating system.
So we and you can't do anything to run this printer on your Mac Laptop.
I hope this help you lot.
Please rate the solution.
Scott
Nov 11, 2008 | Office Equipment & Supplies
12 people viewed this question
jasbo
jasbo
