Pelonis ho 168
Heater not turning on. Not getting any power (power light not coming on)
SOURCE: caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Posted on Oct 23, 2008
SOURCE: pelonis model HO157C0110 will not turn on
Bypass the 3 way (hi, med, low) switch, unfortunately it'll always be in the high position when you do this. I have done this with one of my heaters and as long as the thermostat is working properly then it will work as it should on the high setting. I took the extra step of connecting the LED light to the bypass so I know when its on.
Just remember to turn it off you'll need to unplug it.
Posted on Feb 06, 2009
MNfisherman
  • 11896 Answers
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
Posted on May 15, 2009
SOURCE: i need a switch for my heater,how do i order the
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Posted on Jan 08, 2011
heatman101
  • 43501 Answers
SOURCE: What kind of oil do
Those units are factory sealed and cannot be filled/refilled...
Here is a tip that I wrote about that..
Oil Filled Radiator Heater Leaking
heatman101
Posted on Jan 18, 2011
Need KSD-301-V thermo switch for a Pelonis HO-O218 oil filled heater
Amazon has lots of these thermostats available from 3 to 5 dollars. This is the most common thermostatic switch failure for the Pelonis heater . Go to Amazon and type in KSD 301 in the search area. The temperature rating of the sensor is approximately 305 degrees
Jan 31, 2015 | Pelonis Heating & Cooling
Pelonis oiled filled heater ho-0218 won't heat up
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm. no you do not need to add oil, if the unit leaks throw it out.
Mar 24, 2014 | Pelonis Heating & Cooling
Manual for pelonis oil heater HO 0228D?Digital.
The manual is NOT at the lazy link above. This is genera l link for SOME Pelonis oil heaters but not this specific one HO-0228D
Dec 10, 2013 | Heating & Cooling
My pelonis oil heater has a diode? on the blue power wire behind the end cover. i think this is why mine does not work. can you help me find a replacement?
It looks like a diode, but it's actually a thermal fuse. 128 degree Celcius, marked d125 with a blue stripe. I just replaced mine with a 15amp, 128C, d125.
Sep 21, 2010 | Pelonis Oil Heater HO 157
I need a switch for my heater,how do i order the on and off switch for my oil heater pelonis-model#Ho-157c0109
Feb 09, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Looking for manual FOR PELONIS HEATER MODEL#
May 15, 2009 | Pelonis Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
