Question about RCA DSB778W Wi-Fi Streaming Media Player
Download manual for RCA DSB778W
Will not connect to network
I can't connect to the network/ wifi for my RCA home theater system, I tried putting in manually but still nothing. Please Help.
Does your RCA see the network? IF so, go to it's settings and assign a static IP to it in a proper range (check router settings first). Then connect manually to this IP (point out connection to that IP in settings).
Feb 26, 2015 | RCA Audio Players & Recorders
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
Can't get to Netflix - stays at privacy policy statement
My sister is having the same problem with her RCA box for the last 24 hours.
Mar 06, 2014 | RCA DSB778W Wi-Fi Streaming Media Player
Can't get input on tv to activate rca wi fi streaming media player
depends on what input port you plugged into. HDMI1 HDMI2 HDMI3
the tv input select source has to match
I have a similar device plugged into HDMI3 so I select on the input source HDMI3 to see it on the TV.
Dec 29, 2013 | RCA DSB778W Wi-Fi Streaming Media Player
How do you connect a RCA router to a Sansung HD TV with Xfinity update
Mary, if you have internet, you will have a modem device. This device may be part of the router or it may be a separate unit. In any case, once this is determined and your internet is shared you will be able to connect your tv to your router. Your tv may be a wifi compatible set or not. Depending on which type of set you have, you will either connect a cable to the router or you will have to set up wireless. Wireless will be configured on your router. Once this is done, you can configure your tv to use the wireless connection. For more information, I will need exact make and models of your modem, router and tv. Also, google is a great source for documentation. If you decide to tackle this on your own, set up your modem, set up your router, then set up the tv. Hope this helps.
Oct 06, 2013 | RCA DSB778W Wi-Fi Streaming Media Player
Www.SurroundBar3000instanthome theater
Hi Betty Jean, my name is Mike Houston a Social MediaRepresentative at DISH Network. All of our HD receivers and our SD DVRreceivers have an optical connection, allowing you to connect from your soundbar to the receiver. You can connect the sound bar directly to your TV (witheither RCA cables or Optical Cable); this will give the sound bar audio on all components.I will provide the owners manual for your sound bar. If you have any questionsplease e-mail me at Michael.houston@dishnetwork.com;http://www.polkaudio.com/downloads/manuals/home/SB3000IHT_EnglishManual.pdf
Jan 19, 2012 | Polk Audio SurroundBar® 50 Rear Speaker
RCA DCM245R Modem Vista
Hi Ken:
That's not my expertise but you could try installing some drivers: rca-thomson-dcm245-driver.html
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 25, 2011 | Thomson RCA DCM245R Modem
Looking for tv manual for RCA XL100 F19207BC
MANUAL for RCA XL100 F19207BC Television
The official RCA XL100 F19207BC manual can be located HERE
Alternatively, you may type
http://download.rca.com/FilesForRCAcom/Manuals/15127650.pdf
in your web browser to access the document from RCA's Consumer Television Customer Service website.
May 22, 2011 | RCA Televison & Video
I have a canon Power Shot A520 and want to download several moving pictures to a DISH network TV.I have the interface cable (that came with the camera) attached to both the TV and the camera as I did to...
Page 114 in the manual gives details.
1. Turn camera off.
2. Connect the AVC-DC300 cable to A/V out terminal on camera, and yellow RCA jack to the Video In port and black RCA jack to Audio In port on the television.
3. Set television for Video input.
4. Turn on camera.
5. If no picture on television, press the Display button on the camera (to turn off the LCD display on the camera).
Jul 21, 2008 | Canon Cameras
RCA DSB778W Wi-Fi Streaming Media Player Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
