Question about HQ Cages - Stands Parrot Cage Opening Top w/ Cart & Shelf by HQ 92217C
Assemble HQ 92217C bird cage
Assemble instructions
What is a play-top bird cage?
A play-top bird cage is ideal for active birds. They are designed with a play area that sits on top of the cage's surface. Some models are designed with a detachable play top that allows you to remove it and take to any room of your house. Here is an example of a play-top bird cage -
Aug 29, 2012 | Birds
What is the difference between a welded and knock-down bird cage?
Welded cages are one piece, while knock-down varieties often require at home assembly.
When it comes to bird cages, why is size so important?
Cage size is a very crucial element in regards to proper bird care. The tail of your bird should never touch the back or bottom of the cage when sitting on their perch. A very general rule to follow is that the width of the cage should be at least 1-1/2 times as wide as your bird's wingspan. Keep in mind that it is not just your bird(s) inhabiting the cage but you will need a perch and most likely some toys. My personal recommendation is to buy the largest cage you can afford.
What's a single bird cage?
The single bird cage comes in a variety of sizes and is suitable for only one bird. Check bar spacing and the width of your bird's wing span to determine the best bird cage fit. Elevate this bird cage to sit at a human's chest level.
Aug 05, 2012 | Birds
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
What's a playtop birdcage?
The playtop bird cage provides a space for your bird to exercise and explore its freedom outside of the bird cage, and usually includes bird cage feeders as well. A solid top on the playtop bird cage is excellent for collecting food and other bird messes while the bird is on top of the bird cage.
Does the size of my cage matters for my birds?
In general, the larger and the more active the bird, the larger the cage one should use. The amount of time the bird will spend in the cage each day is also a factor. A bird that is caged most of the time requires far more space than a bird caged only at night.
Do bird cages need to be assembled?
In most cases the bird cages arrive unassembled and you should put it together by yourself. Although you can find many companies that will to it for you.
What's a bird cage commonly made of?
The quality bird cages are often made of iron and the top quality are made of stainless steel. You can find other bird cages lessen in quality with low quality powder-coat or a painted finish.
HQ Cages - Stands Parrot Cage Opening Top w/ Cart & Shelf by HQ 92217C Logo
713 people viewed this question
