Stops after run
Starts & runs for a min or two then stops & smokes. i have already put in a new plug & flter
SOURCE: reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Posted on Nov 22, 2008
  • 3 Answers
SOURCE: heater runs for 2 to 20 mins stops and smokes
I just had the identical problem in the shop. Found the fuel filter almost completely clogged. Replaced the filter and it ran great.
Posted on Dec 24, 2008
SOURCE: Mower smoking and sputtering.
Sounds like the engine is getting flooded because the carburetor float needle is not seating. Let me know if this helps.donnyb60
Posted on Mar 23, 2009
rwvanlue
  • 486 Answers
SOURCE: stihl bg 55 blower runs good for 5 min. then loses power
1) carburetor gaskets/diaphragms may need to be replaced
2) ignition coil may be breaking down when hot
3) check compression when cold, then after it stops, when hot
4) could have a vacuum/pressure leak
*I would investigate carb first
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
keith91gmc
  • 52 Answers
SOURCE: The heat pump starts runs 2 min. stops restarts 7
sounds like it could be low on charge and if it is a scroll compressor they are known for a noise on shutdown
Posted on Dec 19, 2009
My '99 chevy truck with 5,7L 350 will start but wont stay running. put new fuel pump and relay switch in
First you must determine if the fuel is stopping or the spark is stopping..If the fuel is stopping this could be a computer problem.. If the spark is stopping then it could be the IGN Module in the distributer. or any nomber of sensors. Squirt a little fuel directly into the Throttle body on the intake manifold.. If the truck runs longer its probably loss of fuel.. Do this several times to make sure, be careful and only use a small amounty of fuel.. you do not want a fire.. RE: Spark: Take a plug wire and an old plug..put the wire on the plug.. hold the plug against a good ground .. have someone crank the engine .. does the plug stop firing? The engine dies.. and will not restart for a minuet or so.. during this "no start" time do the plug test. If the plug will not fire during this time take the module out and take it to Orillys Auto parts.. They can test it.. really expensive part. Don't replace until you know it is BAD..
May 14, 2014 | 1999 Chevrolet K1500
Smoking white
Probably going to need new piston rings. Pretty sure your burning a little oil.
Feb 10, 2014 | Suzuki Motorcycles
4g63 delica black smoke running rough
You have a failed head gasket
Major repair
Hope you didn't think the stop leak was
a genie in a bottle,never need any product
in any vehicle,just the proper repair
White smoke was coolant ,should have known that
Nov 24, 2012 | 1996 Mitsubishi Eclipse
Service engine light is on and running really rough
probably not module if it restarted within a minute of dying if it smokes black it is most likely fuel system related possibly fuel pressure rewgulater also check coolant level in radiater could also be vacuum leak check egr valve
Apr 06, 2012 | 1992 Chevrolet Astro Extended
Every morning i stard my car it stard to smoke i drive for about 10 min and the smoke stop complectly...what could it .Is there that i can i put in my engine to make it stop smoke
most likely the valve guide seals when motor warms up the every thing will expand and seal alitle better when it cools oil will run down valve stem and sit in head until you start it again
Mar 02, 2011 | Mitsubishi Galant Cars & Trucks
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
94 chevy 1500 will start for about 30 mins. and then just stop
Does it blow black smoke when it's hot? if so, Replace the cold start sensor. If not check to make sure your cats aren't plugged, (they will get red hot). If they are plugged the engine will loose power and stall.
May 29, 2009 | 1999 Chevrolet Silverado 1500
Smoke problem
hey
there are couple of smoke type.blue smoke is oil, black smoke is fuel, and white smoke is water, if it clears after starting and running a few minutes it's probably your valve guide seals leaking oil down on top of your pistons, causing it to smoke until burned off and foul your plugs.
Jun 28, 2008 | Peugeot Liberte Cars & Trucks
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
