Question about Westinghouse 32-inch Led-lcd Tv - 720p Hdtv Television Set
Where is the enter key on the Westinghouse led tv
How do I reset my tv or set it up
Westinghouse 40 Lcd Manual - Heroku
gfdc.herokuapp.com/Westinghouse-40-Lcd-Manual.doc
Westinghouse 40 Lcd Manual - gfdc.herokuapp.com ... led 1080p hdtv - westinghouse 40 class 39 5 diag led 1080p hdtv black model dwm40f1y1 c ... lcd hdtv - buy westinghouse uw40t3pw 40 1080p 120hz lcd hdtv led lcd tvs amazon ... 1080p hdtv dvd combo user s manual vk 40f580d tv dvd combo pdf manual download, ...
Sep 17, 2016 | Westinghouse 40" Class LED 1080p HDTV...
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
Purchased the Westinghouse tv 3-6-15. Sound is going.
It's a off brand TV. Bestbuy has a bunch of offbrand TVs for $150 us.
Oct 26, 2015 | Westinghouse 32in 720p LED HDTV - LED TVs
CAN WESTINGHOUSE 55 INC TV CAN BE PROGRAMED WITH DIRECTV REMOTE
Setup Instructions
  1. Set the "Mode Switch" to TV.
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code 10451
Dec 27, 2014 | Westinghouse Televison & Video
Need directv code for a Westinghouse VR-4085DF Television. The ones posted on Directv's web site do not work.
Need the firmware update and the codes still do not work... About ~ 40 scans in and my vr-4085 worked. Tried all codes prior. No luck.
This works on rc-65
There is no other setup code indicated for your product
that links to the model number you entered.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    • 1 for Televisions
    • 2 for "AUX 1" devices - VCRs or DVDs
    • 3 for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Dec 09, 2010 | Westinghouse 16093 Remote Control
White westinghouse tv code for remote control? And the procedure to program it.
pepelule
Here are the codes for your White Westinghouse TV: 719, 500, 659, 664, 670, 672, 674
I have also included the instructions for programming the remote to your TV. I hope this helps.
  • Remotes: Basic (Television Only)
    1. Turn the Television On
    2. Press and Hold the TV Power button for three seconds until the LED flashes
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Oct 25, 2010 | DISH Network IR Remote Control
Remote codes for directv HD DVR and westinghouse tv
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10463, 10623 Westinghouse 00002 dvr hd
Jun 20, 2010 | Sony STRDH810
All for one remote urc-3021boo for
Try reprogramming the remote with the control codes again.
To control a White Westinghouse TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0463, 0623
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
Codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Oct 10, 2009 | Innovage Jumbo Remote Control
Westinghouse 32-inch Led-lcd Tv - 720p Hdtv Television Set Logo
20 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
