Question about Bodum Kitchen Appliances - Others
Bodum toaster lever does not stay down.
Please help
Falling Down
  • 67 Answers
SOURCE: Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
Posted on Nov 30, 2007
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
SOURCE: toaster arms will not stay down
Arms stay down by the mean of an electromagnet, controlled by a chip. If the wall outlet is functional, you should be able to turn on light by pressing the "defrost" or "bagel" button while the arm is held down. No light? the toaster is good for garbage!!
Posted on Jul 10, 2009
EwingElect
  • 276 Answers
SOURCE: toaster control lever will not stay down
Unplug the toaster, turn upside down, and gently shake all crumbs out. There's been plenty of times when a stray raisin causes this problem!
Otherwise there may be a break in the element. In Australia toasters won't stay down unless the power is connected, and if there is a break in the element there won't be a continuous circuit.
Posted on Nov 30, 2009
  • 16 Answers
SOURCE: When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Posted on Apr 20, 2010
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Finding parts
Have you searched the Internet? If you Google the following; "Bodum toaster parts", you should be able to find them that way.
Apr 19, 2014 | Bodum 10709 Toaster
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
Control lever does not remain depressed
Over manual use can damage the unit over time. There could be particles tucked under the latches, contacts, and other attachments. Clean the catch tray and turn the entire toaster over and shake it violently. If you have vacuum with air OUT and you can place the hose up to the slots, blow from both the top and bottom to push out debris.
Feb 27, 2014 | Bodum Bistro Toaster
Lever wont stay down, no red light
Two possibilities:
1:A wire has come off your toaster switch or plug top,shorted and blown the fuse, and all you would need to do was refit wire and replace fuse.or
2:The element has gone........probably cheaper to buy a new one
Hope I have resolved you question, but please leave positive feedback if so , as it still takes time to answer questions and it would just be nice to know if I have helped
Aug 12, 2009 | Dualit Lite 2 Slots 2-Slice Toaster
VersaToast T1400
THERES A RECALL ON THIS TOASTER CALL BLACK & DECKER @866-264-9230 FOR A REPLACEMENT TOASTER ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 09, 2009 | Black & Decker T1400BD Versatoast Cool...
Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Toaster lever wont stay down
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Feb 23, 2007 | Kenmore KTES4 4-Slice Toaster
Kitchen Appliances - Others Logo
51 people viewed this question
Top Bodum Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Bodum Kitchen Appliances - Other Expert? Answer questions, earn points and help others
