Question about TechnoMarine Cruise Watch
I want to remove the back cover off of my technomarine watch
4 Suggested Answers
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Posted on Sep 29, 2008
escapement
  • 2334 Answers
SOURCE: i need to remove watch links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
  • 906 Answers
SOURCE: how much the technoMarine watches?...
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi Guest,
Please feel free to browse the above link for the price of technomarine watches.
Thank you.
Posted on Jul 28, 2010
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
I have a Techno Marine diving watch. It just stopped. How do I best replace the battery. Myself? Or do I need to send it somewhere? Cebron
Thank you for contacting FixYa.
NEVER attempt to replace a battery on a diving watch yourself. It will break the seal.
You will need to send back to Technomarine or take to a registered Technomarine service center.
You can find information here:
http://www.technomarine.com/Customer/Services.sls
Best regards! Jewel
Oct 05, 2010 | TechnoMarine RSQC11 Wrist Watch
Hello i recently bought a technomarine watch and it is not moving. what do I have to do?
If you bought it recently, bring it back to the place you bought it from and ask for replacement.
Aug 05, 2010 | TechnoMarine DTC55C (Size: Unisex Adult)...
How much the technomarine watches?
Link
Thank you.
May 20, 2010 | TechnoMarine Apnea 35mm Watch - Silver...
I Have a problem with my Technomarine ABS05. There is changed a battery by someone. but the watch doesnt work. I removed the back and some oil came out. where can i find that sort of oil? How can I change...
Oil should not come out of a watch. There just isn't that much oil in a watch to have it dripping out.
Are you sure it wasn't water? I can see where moisture could have gotten inside the watch if it was not sealed properly after the battery change.
The fast mall battery change places, jewelers and mart stores do not hire people that are trained to change batteries properly. We have a love hate relationship with those places. We love them because they keep us in business with all the watches they damage. We hate that they are in the business of replacing batteries in the first place because of how many watches they damage.
If you had one of those cheap battery stores replace the battery most likely they did not reseal your watch and it got water inside. This water will cause the problems you have now with your watch.
You will need to have a qualified watchmaker repair your watch.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 16, 2010 | TechnoMarine Abyss ABS05 Watch for Men
How to change the strap of leather to the gel strap technomarine
What is the reference of the watch? On the Cruise collection, the process is very simple: 1.      (To remove band) Squeeze the easy release spring bar to one side until it detaches from the watch case completely, do the same for both bands.
2.      (To attach new band) Take the straps that you want to put on and squeeze the easy release spring bar with your (nail or screwdriver) and insert into little groove, it should snap right into place
3.      Do the same for other band
If you need more information, please contact us customerserviceus@technomarine.com
Feb 13, 2009 | TechnoMarine Red SquareRSQG19
Technomarine watch battery replacement
Sep 27, 2008 | TechnoMarine Apnea 35mm Watch - Silver...
Stress fracture in case
Contact Technomarine http://www.technomarine.com/
Jun 03, 2007 | TechnoMarine Ceramique Watch TCB02C
TechnoMarine Cruise Watch Logo
19 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
