Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Sc: 829 code: 301
Detail: A4000080. Since she show this error we don't have machine to work. What is wrong?!
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: sc:829 code:301 detail:A4000001
there is something wrong in that machine this making it display this error code. The error code has a meaning and this meaning needs to be interpreted first, before the problem can be identified.
The error code means; charge Corona problem. The charge Corona of your machine is defective and that's what causing the problem. The charge corona is a power pack and it is located inside the drum of the machine.
To be frank, you will need
a technician to help you service the machine in other to get it fixed.
Good luck.
Posted on Oct 09, 2010
As i power on my ricoh mp2000le this is the error i saw. sc 829 code 301 detail ac000000. whats the meaning and solution?
here are some reasons.
1.Self-diagnostic Error: Optional RAM
The optional RAM returned an error during the self-diagnostic test
Resolution - ( Replace the optional memory board
- Controller board defective.
2.Charge roller current leak
The polling module detects a current leak of the charge roller. Causes as follows' • Defective charge roller
• Defective high voltage supply board
• Loose connection of the PCU.
Feb 26, 2015 | Ricoh Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
ENG:prcon.c
Turn ON the copier ,enter in SP mode as follows:
Press the mode/clear(yellow)key
enter "107"
press the clear/stop (red) key for more than 4 seconds
Touch SP mode on the display
Open the front cover
Turn OFF the copier
Wait 3 minutes
Closed the front door
Turn ON the copier.
This error code appaires when using for use OPC drum and not original genuine Ricoh parts(Katun and other brands)
Feb 14, 2013 | Ricoh Aficio 2035 Copier
Error code 301-0001 on i-sensys MF 4450
Show error code 301-0001 after press (Problem with Canon i-SENSYS MF4140 All-In-One Laser Printer
Error code 301-0001 on i-sensys MF 4450cont: 8016185745-dulal
Nov 27, 2012 | Canon i-SENSYS MF4140 All-In-One Laser...
SC:829 code:0301 detail:0xA4000004
ram ,printer broad or hard disk board will have some problem try replacing after cross cheking
May 05, 2012 | Ricoh Aficio 2022 Black and White Copier
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
capacity.
2. Duplex setting is set for a single surface
model.
Apr 08, 2011 | Sharp AR-M205 Copier
Ricoh 1035 laser problem
sometimes the plastic of the laser is turned by the heat proves to relax and to fit the screw that holds the laser unit that is of the side of the drum while it raises a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well be positioned correctly.
Other
Poor connection between the laser
synchronization detector board and
the LD unit.
Laser synchronization detector board
out of position
defective
LD unit defective
May 07, 2009 | Ricoh Aficio 1035 Copier
Machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Jan 20, 2009 | Gestetner DSm615 Digital Imaging System
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
144 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
